01-31-2014, 08:49 AM | #1 |
Newbie Join Date: Dec 2013 Location: philadelphia
| battery upgrade
well i decided to get rid of my nigh batteries in my scx10 all my other cars and helix use lipo so my lhs had a super deal on some venom 2s 25c 10,000mah batteries for 46 a piece so grabbed 2 I'm thinking using traxxas connectors at the moment any pros or cons to using these connectors i was never a big fan of deans but all suggestions are welcome
01-31-2014, 09:03 AM | #2 |
Newbie Join Date: Dec 2013 Location: Fort Saint John
| Re: battery upgrade
That battery will make it super heavy!!!!!
01-31-2014, 09:25 AM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: battery upgrade
Those batteries must weigh a ton!! However, if you like traxxas connectors, use them!
01-31-2014, 09:27 AM | #4 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
| Re: battery upgrade |
01-31-2014, 09:28 AM | #5 |
didn't get a chance to weigh it yet but its not as heavy as i thought it would be but i figured id give it a go ill weigh it up tonight just weighed it 17.3 ounces yeh i no no need but the price was right if it feels too heavy ill swap em out for something lighter new to crawlers so just trying different things Last edited by THX_138; 02-01-2014 at 11:59 AM. |
01-31-2014, 09:38 AM | #6 |
| Re: battery upgrade
You should run a pair on top of the sliders to keep CG low and for better balance. But even so, at 17.3 oz. it's a brick. I run a pair of 4s lipo's that weigh 17.3 oz. total.
01-31-2014, 04:29 PM | #7 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
| Re: battery upgrade The batteries are a bit big but you don't weigh anywhere near what a rig would weight with all the aluminum hop ups and such..If you can put that weight behind the trans running parallel its not such a bad thing to have the added weight. It would help you climb up hills better if anything and give added traction on the front. |
01-31-2014, 07:26 PM | #8 |
Quarry Creeper Join Date: Nov 2013 Location: Erie
| Re: battery upgrade
What kind of crazy run time would you get with 10,000mah? 4 hours?!?
01-31-2014, 08:19 PM | #9 |
Pebble Pounder Join Date: Jan 2014 Location: Laramie
| Re: battery upgrade
wow. 10,000 means like a three day run time if you just go out for a like 1.5 hour crawl sesh's! but regarding the connectors, i have always preferred deans just because they have always been a good plug and dont require the precison soldering to fit them into the sleeve (like traxxas). Of course if your ESC is already fitted with traxxas connectors and your buying them with traxxas plugs this may be the better route.
02-01-2014, 10:16 AM | #10 |
| Re: battery upgrade
i got a shitty duratrax esc and it had tamaiya plug on it but i found the traxxas easy to solder considering i suck at soldering |
02-01-2014, 10:51 AM | #11 |
| Re: battery upgrade
With two of those you may never need to use a charger again. As for the Traxxas connectors. I like them a lot and have used them for years. They are easy to solder and work very well. |
02-01-2014, 11:00 AM | #12 |
like i said they were venom and for the price it wasn't gonna hurt me either way I'm really trying to divide on the best motor esc comb but I'm torn between the novak goat novak timbuk2 or something from hh i bought a combo kit from tower it was the rubicon builders kit duratrax esc axial 55t motor a cheap nigh battery and charger re thinking things i should have just gotten the kit itself since I'm replacing everything it came with i use a spectrum dx3c for my 1/5tha scale so the tactrix radio was the first thing i took out lol Last edited by THX_138; 02-01-2014 at 12:00 PM. |
battery upgrade - Similar Threads | ||||
Battery Upgrade | Sethmetal | Vaterra Twin Hammers | 41 | 06-20-2013 02:38 PM |
If you could only upgrade 1 thing, Motor or Battery? | BadRockNoCookie | Electronics | 17 | 06-12-2012 09:31 PM |
battery upgrade | kaistonge | Electronics | 2 | 05-08-2010 07:49 AM |
battery upgrade | D.J.D.H. | Electronics | 11 | 02-19-2009 09:34 AM |
battery upgrade question | TIMZKRAWLER | Newbie General | 3 | 08-16-2007 12:30 PM |
