02-16-2014, 09:39 PM | #1 |
Newbie Join Date: Jan 2014 Location: middle river
| help w g6 build
hi everyone im building my g6 now and came accross a issue. im on pg 26 step 33 when i go to put the screw axa119 though ax80041 to mount the link the screw hits the motor and i cant get the nut on it
02-16-2014, 09:43 PM | #2 |
Pebble Pounder Join Date: Feb 2014 Location: grand forks
| Re: help w g6 build
Yup just back the screw out almost all the way grab the nut with pliers and just give the motor a little push down should be able to get the nut on there then
02-16-2014, 10:05 PM | #3 |
| Re: help w g6 build
that worked, now another issue the servo horn is hitting a brace
02-16-2014, 10:11 PM | #4 |
RCC Addict Join Date: May 2008 Location: Southern,WV
| Re: help w g6 build |
02-16-2014, 10:19 PM | #5 |
found it, ill give it a try in the am, thanks its still rubbing but will do Last edited by THX_138; 04-02-2014 at 03:33 PM. |
02-16-2014, 11:07 PM | #6 |
Rock Stacker Join Date: Oct 2013 Location: Nampa
| Re: help w g6 build
Ditch that second brace, it isn't needed unless you run the battery in the front which is less than optimal.
02-17-2014, 06:01 AM | #7 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
| Re: help w g6 build Bad design by Axial If your running the battery in the stock location, I took my dremel and just trimmed the crossmember until it cleared the servo arm. Or like the guy above said, relocate the battery and eliminate the the crossmember all together. Last edited by billj; 02-17-2014 at 07:49 AM. |
02-17-2014, 07:17 AM | #8 |
Rock Crawler Join Date: Oct 2012 Location: Casper
| Re: help w g6 build
No, you don't want it in the rear, either. Look closely at the above pic. His battery is in the front, custom mounted behind the shock towers. The other "good" option is twin batteries mounted on top of the slider mounts.
02-17-2014, 10:34 AM | #9 |
ok ill pull the brace and move the battery to the rear. thanks again for all your help Billj can you give me a better ideal on how you have the battery mounted Last edited by THX_138; 04-02-2014 at 03:34 PM. |
02-18-2014, 09:14 PM | #10 |
| Re: help w g6 build
just a update about the motor hitting one of the upper link screw, i ended up taking some of the lexan that was left over from cutting out the body and made a shim using two pieces of it and put between the trans and plate that it sits on
help w g6 build - Similar Threads | ||||
Tamiya CC-01 Landfreeder Build Thread (Build Complete) | TheBlueKnight | Tamiya XC/CC01 | 29 | 11-24-2014 11:21 AM |
Jeep scaler build and comp micro crawler build | droopmodmrc | Losi Micro-Rock Crawler | 1 | 12-25-2012 12:34 PM |
~53 Willys 2010 Comp Rig Build~ RC4WD MOA Worminator Build~ | 53 willys | General Crawlers | 108 | 11-28-2011 12:42 AM |
RcBros LCC Build, Hi-Res pics & More Build!! | RcBro | Team Losi Comp Crawler | 30 | 06-03-2009 07:26 PM |
