02-19-2014, 07:53 PM | #1 |
Newbie Join Date: Feb 2014 Location: Avondale
| My first build (Honcho RTR rebuild)
So I picked up this used Honcho at my LHS. Body was beat up so I cleaned it up some made a re-enforcement plate for the back of the cab and sprayed the cab inside and out. Broke a couple of lower links and had to replace them and since I am new I found some adjustable links to replace them. Made two trays that mount to the frame above the sliders inside the body to hide two batteries for long trail runs and lots of crawling. Any suggestions and info are always appreciated. Questions are answered as best as I can. Sent from my iPhone using Tapatalk |
02-19-2014, 08:03 PM | #2 |
| Re: My first build (Honcho RTR rebuild)
are those 1.9 flat irons for tires?
02-19-2014, 08:05 PM | #3 |
Yeah they are, they came with the truck I am looking to replace them with pitbulls or tsl XLs Sent from my iPhone using Tapatalk |
02-21-2014, 10:02 PM | #4 |
Ok so I went to my LHS and picked up some TSL SX XL 1.9 for the truck, finished the battery trays, got the new headlights put in and winch wired up, and new front bumper put on. As always comments and questions are welcome. |
02-28-2014, 07:21 AM | #5 |
Pebble Pounder Join Date: May 2010 Location: Phx
Looks like your off to a great start with your truck. Those TSLs look and work way better then the flat irons imho.
03-01-2014, 07:33 PM | #6 |
Will a 16 tooth spur gear be fine with a 35 turn motor until I use the two motor kit Sent from my iPhone using Tapatalk |
03-13-2014, 08:56 AM | #7 |
| https://onedrive.live.com/?cid=3e681...JvRuxmrnv6ZtRI I just finished a dual motor install and was testing it and I found a week point as you can see by the last photo Sent from my iPhone using Tapatalk |
03-13-2014, 10:10 AM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
Those TSL XL's look great on that thing.
03-13-2014, 10:31 AM | #9 | |
Rock Stacker Join Date: Jan 2014 Location: Utah, USA
| Re: My first build (Honcho RTR rebuild) Quote:
Just wanted to tell you that your truck is looking sweet. I know a lot of guys done like those 1.9 flat irons, but I wish I could get some. I have the 2.2's on my sons rig and they work really well. Keep up the great job on your build. Last edited by CodesEmpire; 03-13-2014 at 10:34 AM. | |
03-13-2014, 11:00 AM | #10 |
Yeah I have the flat irons as backups I am running the TSL SX XL's now and yeah I was talking about the pinion gear. Now I am running two 35turn tekin hand wound motors and 25tooth pinions with a 87tooth spur Sent from my iPhone using Tapatalk |
03-13-2014, 01:28 PM | #11 |
Ordered a set of Robinson racing gears for the tranny, will see how that goes hopefully that will eliminate the breakage problem. Have been thinking about doing the gen3 slipper clutch from Robinson has anybody had any experience with it. Sent from my iPhone using Tapatalk |
My first build (Honcho RTR rebuild) - Similar Threads | ||||
New guy, SCX10 Honcho RTR, a few questions about my Honcho | dan188 | Axial SCX-10 | 2 | 10-04-2013 09:43 AM |
Swamprat86's build of the Honcho RTR | swamprat86 | Axial SCX-10 | 7 | 09-08-2012 10:57 PM |
The Marmot - SCX10 Honcho - Rebuild with 100mm shocks | dystance | Axial SCX-10 | 41 | 06-20-2011 01:17 PM |
One Honcho RTR make over (CHOP, CUT, REBUILD) | XxRockStar199xX | Axial SCX-10 | 9 | 04-26-2010 08:24 PM |
