Thread: New scx10 unlimited rubicon kit
Old 03-11-2014, 06:22 PM   #1
Default New scx10 unlimited rubicon kit
My kit arrived today, this will be my first scaler/crawler/trail truck.
I have awesome terrain right behind my house, hills/rocks/trees, it is prime.
I have a justock esc and 17.5t motor that was in my buggy I recently sold as a roller. as well as an extra receiver for my futaba 3pl, so all I would need to go would be a servo.
How much torque should I look for in a servo, also should I get a castle bec?
TrailerBash is offline   Reply With Quote
Old 03-11-2014, 07:34 PM   #2
300+ oz servo and yeah I would get a bec while your at it
BuIlT nOt BaUgHT!
509hooligan is offline   Reply With Quote
Old 03-12-2014, 12:18 PM   #3
Default Re: New scx10 unlimited rubicon kit
Deff want a bec and a good servo and hd servo horn
blumaro is offline   Reply With Quote
Old 03-17-2014, 08:34 AM   #4
Decided to not use the sensored in the scx10, I moved it to another vehicle, plus I want the scx10 completely waterproof.
I ordered a HH torquemaster brxl waterproofed with the 27t sport motor combo
Savox 1210sg waterproof servo...277 oz of torque @ 6v, should be good,I wont be doing HC crawling, more trail runs with light crawling thrown in, I was going to get the 1230 but I really dont like voiding warranties waterproofing non waterproof electronics.
I have a bec set to 6v on hand if the brxl bec cant handle the servo
And I picked up 2 new 3s 2200 mah lipos, should be awesome with the 27t motor, I also have tons of 2s lipos for when I want to slow it down.
And my LHS had a can of pactra fiery orange paint...HELL YEAH
Just need a day off to get it built lol, life never fails to take all your time when you need some lol
Old 03-20-2014, 01:50 PM   #5
Started the build, both axles are giving me a problem, when I put the ring gear in and turn it everything feels nice, when I put the case together it has a clunky clicking noise, I can feel the teeth knocking.
Pulled it apart, made sure bearing under the pinion was seated all the way and tried again, same thing both axles.
Gasket is inbetween gear and locker, greased, no noticable burrs on the gears or axle case.
It is driving me nuts
If it is defective out of the box I am going to be completely dissapointed, I was really lookinf forward to this build but this is getting annoying.
I watched videos, read posts, I am doing nothing different, the directions are pretty simple, I dont think I am doing anything wrong.
can anyone help me past this.
Old 03-20-2014, 01:58 PM   #6
Some screws are a bit too long, and when you tighten them, they will grind on the axle shafts, put everything back together, and if it feels choppy, start backing off a screw one by one.
69rd96 is offline   Reply With Quote
Old 03-20-2014, 08:19 PM   #7
Try pushing the inside pinion breaking in farther... mine did that and I had to tap the bearing down farther with a little hammer.
BuIlT nOt BaUgHT!
Old 03-21-2014, 06:38 AM   #8
Thanks was thinking about the hammer, I have the axles at work today, going to tear them down during breaks and lunch today, I hope it helps, will let ya know how it goes.
Old 03-21-2014, 11:18 AM   #9
Worked, they are nice and smooth now tyvm.
Got some work done today, shocks built, strc upper links, axial lower links, shocks and drives installed.
built the trans, it is so smooth, also got my treps mounted on my axial 8 hole beadlocks.
Tonight I will attack the frame
New scx10 unlimited rubicon kit - Similar Threads
Evols Axial SCX10 Jeep Wrangler Unlimited Rubicon JK *kit version* ev0l Axial SCX-10 97 01-09-2016 07:17 PM
NorCal's Axial SCX10 2012 Jeep Wrangler Unlimited Rubicon Kit Build NorCal 2500HD Axial SCX-10 29 06-20-2014 09:59 AM
