03-13-2014, 05:49 PM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Champlin, MN
| She studders and stops. Assistance required!
So I've done a handful of mods to my lovely truck here and somewhere in the middle I done goofed good. Could use advice and help to figure out what went wrong where if anyone knows about my issue. On a fresh new pack the truck runs fantastic, after a minute or three it studders like it's signifigantly low on battery power, give it a little less throttle and it runs good for a few seconds then it's bad. give it hardly any throttle and it runs fine for a minute or two and studders. its got a sever Jerk jerk jerk jerk issue. The lights twitch with the motor motion so I think it has to do with my Receiver not getting consistent power. It has done this WITH a Ubec, and without. it's also done this on both a 6 and 7 cell Nimh pack (Lipo cut-off is OFF) things that changed since it last ran good: 1.(don't cringe) I liquid electrical tapped the reciever, seen it done quite a few times and it all worked for them. it sat for over a week before i ran it again so I know it was all dried by then. 2. Installed (then removed) a Ubec. 3. installed a Traxxas style battery connector. (issue occured with my old Tamiya style connecter as well, so I eliminated it as a possibility.) Nothing is warm to the touch, so I don't think heat is an issue, and the ESC does go through all the binding steps and programming just fine. but I can't take my rig out when I can't drive it! Any tips or advice here? EDIT: added video Video of the issue, pardon my AWEFUL video skills but there isn't too much to see. https://www.youtube.com/watch?v=D8yP...ature=youtu.be Last edited by Intashu; 03-30-2014 at 12:42 PM. |
03-13-2014, 08:11 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: northern
how many lights are you running and are they connected to your main battery or are they run off of a separate power supply Sent from my iPad using Tapatalk |
03-13-2014, 08:14 PM | #3 |
Rock Stacker Join Date: Jan 2010 Location: Tijeras
| Re: She studders and stops. Assistance required!
Are you running the stock ESC that comes with the Axial scx-10 and wraiths? I had an issue similar to yours and it turned out that the stock switch was broken and dying so it would studder.
03-14-2014, 08:17 AM | #4 |
the stock lights that came with the Dingo Truck, and the stock AE-2 speed controller that comes with the RtR. lights are powered through the receiver as it come stock.
03-14-2014, 11:28 AM | #5 |
Newbie Join Date: Mar 2014 Location: Vegas baby
I'm guessing esc or receiver issues if you have a local club you could swap parts with known good parts and find the issue that way
03-14-2014, 11:35 AM | #6 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
Check for binding anywhere check the esc and see if it or the motor is getting hot Sent from my SCH-S738C using Tapatalk |
03-14-2014, 12:48 PM | #7 |
nothing is hot. and nothing is binding. and unfortunately I don't belong to any clubs nor know of any in my area.
03-14-2014, 01:42 PM | #8 |
I used a throw away crappy ESC I had sitting around (one with severe neutral position issues) and the stuttering issues appear to stop. (course the truck also does not stop when neutral isnt set right!) SO this tells me it's my AE-2 Speed controller that's having the issue. D: any tips? |
03-14-2014, 03:32 PM | #9 |
Replace it....
03-14-2014, 04:34 PM | #10 |
| Re: She studders and stops. Assistance required! |
03-14-2014, 04:39 PM | #11 |
U can get them off ebay for under 50.00 Or scan classifieds here for good used ones |
03-15-2014, 01:48 AM | #12 |
Quarry Creeper Join Date: Oct 2008 Location: Finland
I'm not familiar with the axial ESC but does it have an on/off switch? I've had issues with with those switches on other ESCs and eliminating the switch has gotten rid of the problems. |
03-15-2014, 02:48 AM | #13 |
RCC Addict Join Date: Mar 2009 Location: Interior BC
cut the switch off and solder the wires together. Eliminate it! i do it to every RC i own! switches suck |
03-15-2014, 05:14 PM | #14 |
Sigh, one step forward, and 3 steps back. Soldered the tabs for the switch together so I can remove it all together, now the esc beeps in an unusual pattern, refuses to bind, and causes my servo to twitch erratically. I think I fried it. I got a GTB2 laying around, maybe I'll try brushless, since I do more trail driving than crawling anyways. Unless someone knows of this issue too and a way to fix it! ): |
03-30-2014, 12:42 PM | #15 |
Video of the issue, pardon my AWEFUL video skills but there isn't too much to see. https://www.youtube.com/watch?v=D8yP...ature=youtu.be |
03-30-2014, 01:03 PM | #16 |
ESC went to lunch and never came back......
03-30-2014, 06:29 PM | #17 |
03-30-2014, 07:12 PM | #18 |
I had a similar issue with my duratrax baja bug on the 13th of this month, replacing the esc with a cc sct esc fixed it right up..thats why I initially said to replace it |
She studders and stops. Assistance required! - Similar Threads | ||||
axle stops/bump stops limit axle upward movement | meanbgreen | General Scale Talk | 7 | 01-27-2012 03:02 PM |
In need of assistance | bcmusmc | General Scale Talk | 2 | 10-12-2008 10:19 PM |
Need some assistance | chad30w | Oklahoma | 10 | 03-31-2008 09:47 PM |
need some assistance! | mudrinner4ever | Electronics | 0 | 02-12-2007 08:05 PM |
Assistance please! | spitfireo33 | Newbie General | 4 | 10-14-2006 01:28 PM |
