03-14-2014, 11:20 AM | #1 |
Newbie Join Date: Feb 2014 Location: union city
| Problem with scx10
I think its my slipper clutch but I'm not sure. When I drive it seems like it is just slipping and not putting the power to the wheels. Do I need a metal gear?
03-14-2014, 11:26 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Central WA
| Re: Problem with scx10
Tighten the nut on the spur shaft down to tighten up the slipper, see if it improves. A metal gear wont help.
03-14-2014, 11:28 AM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
tighten that slipper nut down all the way...then back it off 1/4 turn...you should be good to go
03-14-2014, 11:32 AM | #4 |
Thanks a lot
03-14-2014, 11:54 AM | #5 |
| Re: Problem with scx10 |
03-14-2014, 11:56 AM | #6 |
Quarry Creeper Join Date: Feb 2013 Location: hawkins
Is the nylon in the nut still good that was what was wrong with my wraith Sent from my SCH-S738C using Tapatalk |
03-14-2014, 11:59 AM | #7 |
Pebble Pounder Join Date: Jul 2010 Location: malta
could be the drive shaft grub screws are loose
03-14-2014, 12:04 PM | #8 |
| Re: Problem with scx10 Take the lid off, hold the rear tire, give it some throttle and watch. Do the drivelines spin? Is there much resistance on the tire? Is the slipper still slipping? Is the mesh between the spur and pinion too little causing poor engagement?
03-14-2014, 12:12 PM | #9 |
| Re: Problem with scx10 Okay I believe my teeth on the plastic slipper is worn down. I can see the difference in the size.
Problem with scx10 - Similar Threads | ||||
Scx10 problem! | OH6HEMI | Axial SCX-10 | 59 | 01-06-2014 07:32 PM |
scx10 problem | husky250rider | Axial SCX-10 | 33 | 04-26-2013 02:21 AM |
axial scx10 problem help!!!!! | mr.imbert | Axial SCX-10 | 24 | 06-12-2012 08:30 AM |
scx10 problem | crawling-wallz | Axial SCX-10 | 11 | 12-09-2010 08:21 PM |
