03-15-2014, 11:28 PM | #1 |
| Frankenstein
Chassis: SCX10 Axles: Axial Shocks: stock Helion Dominus SC Springs: stock front ECX Front Upper Link: Axial Y Link Front Lower Links: Traxxas Revo 102mm Rear Links, Upper and Lower: Traxxas Stampede Camber Links Wheelbase: 10.5 in Steering Servo: stock Axial Steering Links: aluminum Axial Servo Horn: aluminum Futaba Wheels: 2.2 Axial Rockster, 2oz weight in each front Tires: 2.2 Proline Dirt Hawg II Motor: Integy Lathe 35t Trans: Axial Locked Transmission Body(s): Parma 1/10th Grave Digger and Proline 50's Chevy Pick-up Front Bumper: Axial Poison Spyder Driveshafts: Axial long front, short rear It's still a work-in-progress, I don't have the esc, tx, or rx yet, and I want to make fender wells. Last edited by Mike Flea; 03-15-2014 at 11:35 PM. |
03-23-2014, 06:52 PM | #2 |
| Re: Frankenstein
Made the fenderwells out of Cool Whip containers, got rid of the visor, and painted the outside of the body. Also had to put an extension piece on the top of the rear shock towers because the rear shocks were dropping so low, the rear driveshaft was binding at the output shafts of the trans. The pieces I used for the top of the shock towers came from my ridgecrest chassis, they hold the front part of the links to the chassis.
03-29-2014, 08:14 PM | #3 |
| Re: Frankenstein
Put a Duratrax 32p 56t Spur gear in today with a 14t pinion
03-29-2014, 09:07 PM | #4 |
Pebble Pounder Join Date: May 2010 Location: Phx
| Re: Frankenstein
Your rig is coming along nicely. Looks better without the visor and painted on the outside for that matte finish look. The inner wheel wells are a great addition too. But the rear shock angle isn't doing ya any favors. If ya lean the tops forward the whole rear suspension will work alot better & smoother. |
03-29-2014, 09:21 PM | #5 |
| Re: Frankenstein
Ya, I thought about that when I was putting it together, it hasn't been run yet, but I do need to change the angle forward, or at the very least make them straight.
04-07-2014, 06:25 PM | #6 |
| Re: Frankenstein
Moved the tops of the rear shocks forward 3/8'' so now they're vertical, ordered ESC and receiver.
04-20-2014, 08:43 AM | #7 |
| Re: Frankenstein
Installed a receiver & esc last night, and test ran it thru the living room. Man, those 32p gears are noisy, but since I don't have a gear cover, and no where to really attach one, they'll have to do.
04-21-2014, 10:25 AM | #8 |
| Re: Frankenstein
32p gears might be alittle loud, but they will take beating. How did the rig do on its first test drive?
04-21-2014, 07:07 PM | #9 |
| Re: Frankenstein
In the house it ran great, but I need to get it out on the trails this weekend.
05-11-2014, 01:56 PM | #10 |
| Re: Frankenstein
IT LIVES! Finally got Frankenstein out for it's maiden voyage. I wish I was co-ordinated enough to shoot pics or video with my phone while I ran the truck, but it didn't happen. It's probably won't surpass some of the rigs I've seen in these threads throughout RCCcrawler, but I'm very happy with it. It did, however, run, climb, and crawl better than my Dodge wroncho, and both chassis's are set up similarily in that the batteries are mounted in the rear. The only real difference is the wheelbase, Frankenstein is at 10.5", and the wroncho is 12.5", which can be a major plus for the panel, since it didn't hang up on obstacles that the longer wb Dodge did.
05-11-2014, 02:55 PM | #11 |
RCC Addict Join Date: Feb 2008 Location: your back yard
| Re: Frankenstein
I've been out of the loop for a while and loving coming back reading these builds to actually see different rigs.. Loving the tires used on your build. Never been a fan of your body but they way you put it with the W/T combo I'm liking it..
05-11-2014, 03:20 PM | #12 |
| Re: Frankenstein
Thanks Tat
05-11-2014, 03:37 PM | #13 |
Rock Crawler Join Date: Mar 2010 Location: Onalaska
| Re: Frankenstein
Looks cool nice work
05-11-2014, 06:05 PM | #14 |
| Re: Frankenstein
Thanks RJ
05-11-2014, 06:39 PM | #15 |
| Re: Frankenstein
These 2.2 Dirt Hawgs seem to give the truck a lot of stability without raising the center of gravity. I'm running them without foams, and each front wheel has 2 oz of weight. And even with the NiCd pack mounted in the rear, it's perfectly balanced, it doesn't flip over backward throttling up a steep grade, and doesn't tumble end over end going down a steep grade, unless I do something stupid.
Frankenstein - Similar Threads | ||||
Frankenstein | Rok Out | Axial Wraith | 46 | 01-14-2014 05:37 PM |
Frankenstein | Mr. Ed | Losi Mini-Rock Crawler | 7 | 02-22-2009 03:50 PM |
Project Frankenstein | Frkan | Tamiya TLT Crawlers | 13 | 03-21-2005 05:47 PM |
