04-23-2014, 07:58 PM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Isanti, MN
| Would a 4600KV motor work well in an SCX10?
I am currently saving for an SCX10 and after seeing some faster brushless motors being run in scalers I started wondering if I could use my old Mamba max with a 4600KV sensored brushless motor system I got years ago for my stadium truck I later cannibalized to build my first crawler. The motor is in excellent shape and I would just have to gut the ESC out of my old Cole82 Gopher tuber on TLT axles that is going to be shelved anyway. So, would a 4600KV motor work if I geared it down, or would it have too much speed and not enough torque? Also, if it has 3 wires from the ESC to the motor does that mean it's sensored. I'm pretty sure it is if I remember right but I wanted a way to be sure. Edit: Oh, and this isn't the Mamba max pro. This is the original mamba max ESC that is around 8 years old and the motor came with it. I believe it was when castle creations first started doing brushless for cars. 2nd Edit: I dug up the motor and found it is the old Castle Creations CM36s series of motors. I also found out that it is probably sensorless. Will a sensorless motor be alright? I also read that this is about the equivalent of a very good 12T motor. That sounds rather fast. I did read in the instructions that I can lower the timing of the motor which would reduce power consumption and top speed. I wonder if that would work if it is too fast even when geared down. Last edited by theTman; 04-23-2014 at 08:24 PM. |
04-23-2014, 08:35 PM | #2 |
Thats a sensorless motor and it will cog pretty bad trying to crawl with it...better off going with the newer mmp sensored esc and a good sensored brushless motor. I got a new 13.5 tekin redline on ebay for 50 bucks that works great...its sensored and matched up with a cc mmp sensored esc..there is the roc412 but its alot more expensive and i will have to save up for that one...
04-23-2014, 08:51 PM | #3 | |
| Re: Would a 4600KV motor work well in an SCX10? Quote:
04-23-2014, 08:58 PM | #4 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
I'm currently running a 12v dewalt motor in my scx based bronco. On 3s its real good. Crawls good and has decent wheel speed. Also its under $20. My buddy has been running one for a while now and he's not afraid to get it wet. Its outlasted some much more expensive motors for him
04-27-2014, 10:59 PM | #5 |
Newbie Join Date: Dec 2010 Location: Folsom... I think
You need sensored
04-28-2014, 12:52 AM | #6 |
Quarry Creeper Join Date: Jan 2007 Location: Las Cruces, New Mexico
imo brushless is too powerful for the scx10. if you had to go brushless i would think the best thing would be a 21.5 or higher or something between 1000kv to 3000kv. even 3000kv is going to be to powerful for the scx10.
Would a 4600KV motor work well in an SCX10? - Similar Threads | ||||
Emaxx + 4600kv motor | Nitro_Geezer_UK | Non Crawler RC's | 8 | 08-04-2011 01:51 PM |
35t Yokomo Drift Motor work in my scx10 | r34sklnnsn | Electronics | 2 | 01-07-2011 06:36 PM |
4600Kv motor | four12unner | Team Losi Comp Crawler | 3 | 02-18-2010 07:49 AM |
