06-22-2014, 05:02 AM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Strafford, NH
| Rob5059 Honcho build Well I had a set of built up AX10 axles and transmission kicking around on my bench that I was going to build a sporty with, but I really like my LNC so I never did anything with them. I pulled the XR mod off the front axle and found some SCX10 alum chubs, knuckles, and CVD. The next thing I needed was an SCX10 chassis, shocks, and to decide on a body. So I hit the RPP Salvage yard and picked up a SCX10 chassis and a set of Proline 95mm shocks, and found a good deal on eBay for a NIP Honcho body with cage. Now that I picked a body it was time to find some links and electronics. So I went digging through my parts bins and found a Hands Brothers CMS setup and 3-link rear kit, Tekin FXR with 35T, 7955 servo, and some aluminum links. For tires I will be running Axial 8 hole wheels with Mickey Thompson 1.9 Baja Claw TTC. I still have some work to do; I need to wire in the lights, install the Hands Brothers rear 3 link, and tune the suspension. I am running 30W oil in the shocks right now, but I think it needs some heaver oil. Last edited by rob5059; 10-14-2018 at 04:58 AM. |
06-22-2014, 05:18 AM | #2 |
| Re: Rob5059 Honcho build
Front Axle Alum chub Alum knuckles 36/13T gear set HR locker Rear Axle Alum straight axle adapter 38/13T HD gear set HR locker Transmission 87 Spur / 14T pinion HR harden gears Axial machined motor plate WB8 driveshafts Electronics FXR w/ 35T CC BEC HS-7955TG Axial simple LED controller Misc Axial 5 bucket light bar Hands Brothers CMS Hands Brothers rear 3-link kit Bulldog wireless winch Mickey Thompson 1.9 Baja Claw TTC |
06-22-2014, 10:16 AM | #3 |
looks good... should get 'er done. The battery size looks as if it might cause interference with tires when steering fully (lock 2 lock)... at least it would on mine. The other thing I don't get... is folk mounting their Hi-Lift on the hood ? I've seen it more then a few times... But it is the worst place one could mount one IMO. well... at least on a 1:1 rig. ^ unless the painted surface and sheet metal is of no concern. For a poly bodied crawler... can't really mar things up. But on a 1:1... there would be a good chance the sheet metal of the hood would get bent, due to the weight... and a few hard hits. (especially today's/current thin sheet/pot metal) Guess what I'm saying is... in my 1:1 off road experiences... Mounting the HL on the body's sheet metal surface... is not the best of ideas... JMO But if you like it... is all that matters I'll suppose |
06-22-2014, 12:11 PM | #4 |
RCC Addict Join Date: Mar 2013 Location: Commerce Township
IMO....for a "parts bin special" - very nice job!
06-22-2014, 01:02 PM | #5 |
Pebble Pounder Join Date: Oct 2004 Location: Southern Wisconsin
| Re: Rob5059 Honcho build I have the battery mounted there on my G6. I raised the battery tray's leading edge about 1/4 inch off the frame to allow for total clearance through the steering range at full articulation.
06-23-2014, 05:08 AM | #6 |
I will need to check and see if the tires are hitting the battery. I am not sure if I am going to stay with the 5000mh batteries. I have a Wraith interior and it looks like I would need to chop it up quite a bit to use the big battery. I have a bunch of 1300ma 2 and 3 cells that should fit under the interior pretty good.
02-02-2015, 08:00 AM | #7 |
| Re: Rob5059 Honcho build Well the Honcho is under the knife again. It started off the I changed the SCX10 axles for a set of cast Yota axles; 3 link in the front with panhard, and 4 link in the rear. I kept the Hands Brothers servo mount and got a 3 link bracket for a Yota 2 axle. Then I got the rear cage by trading some parts. So I have been cleaning up the cage and making a bed and fuel cell. Last edited by rob5059; 10-14-2018 at 04:58 AM. |
02-07-2015, 12:45 PM | #8 |
Had some time to finish off the fuel cell, and got everything painted and mounted. I have a new cab and I have not decided on a color, thinking of green or red. I have also ordered an assortment on Vanquish TI links.
02-07-2015, 12:46 PM | #9 |
Fuel cell
02-07-2015, 12:48 PM | #10 |
Mounted everything up.
02-07-2015, 05:56 PM | #11 |
Quarry Creeper Join Date: Jul 2013 Location: Maple Ridge B.C. Canada
Looks good, keep up the good work
02-08-2015, 06:10 AM | #12 |
| Re: Rob5059 Honcho build |
02-08-2015, 02:28 PM | #13 |
Rock Stacker Join Date: Jan 2015
Rob5059 Honcho build - Similar Threads | ||||
Rob5059 Wraith build | rob5059 | Axial Wraith | 0 | 09-25-2013 05:36 AM |
My Honcho build | winkscrawler | Axial SCX-10 | 16 | 02-20-2010 01:30 PM |
