06-30-2014, 10:15 AM | #1 |
Newbie Join Date: Dec 2009 Location: Santa Ana, CA
| Is the Warn winch supposed to lock?
Just a quick question that I could not find an answer using search. I bought got a used JK that came with a Warn winch from RC4WD. It uses the wireless fob. If I hold the cable vertically the winch does lift the truck up but it will slide back down when I let go the button. Just wanted to know if this is normal. I have a friend in my group that has the same question. Same thing going on with his. Appreciate the help.
06-30-2014, 11:13 AM | #2 |
RCC Addict Join Date: Feb 2008 Location: Tekin, ID
| Re: Is the Warn winch supposed to lock?
Yep, it's normal. The only way to get rid of most of that is to use an ESC for a winch controller that has drag brake.
06-30-2014, 11:18 AM | #3 |
purdy sure these don't have an auto drum brake like a 1:1 winch. So my guess is... it is normal (in/out) hold/brake is controlled by gear reduction. dead lift is rated at 6.6 lbs. rolling drag is rated at 9. lbs curious as to how much your rig weighs ? excluding the vertical dead lift... does it back out when winching horizontally (normal duty) ? |
06-30-2014, 11:53 AM | #4 |
I'll weigh it when I get home from work. I do have more things on mine which is why it goes down faster than my friends. Thanks for the help. Very much appreciated.
Is the Warn winch supposed to lock? - Similar Threads | ||||
honcho and warn winch | zackS30 | Axial SCX-10 | 9 | 06-01-2014 07:51 PM |
Who sells Warn winch decals for 3racing winch? | Wild Snapper | Scale Accessories | 6 | 12-03-2009 06:38 PM |
warn winch | supercrawlerfreak | General Scale Talk | 20 | 12-24-2008 04:39 PM |
