07-11-2014, 05:42 AM | #1 |
Rock Crawler Join Date: Jan 2013 Location: Australia
| Steering Improvements
Hey guys, as we all probably know, the scx10 doesn't get the best steering radius (or maybe I'm just fussy ). I'm trying to make this short, so if i were going to get the axial hi-clearance knuckles what else would i need to actually get more steering? Cheers, Hammer! Last edited by Hammer!; 07-11-2014 at 05:46 AM. |
07-11-2014, 07:20 AM | #2 |
Newbie Join Date: May 2014
You will need a radio that you can adjust the travel of the steering with and I needed a longer steering link and I switched the drag bar side from drivers to passenger and the spacing and configuring will have to change just play with the steering until you get it right no servo twist when fully locked out or as little as you can
07-11-2014, 07:27 AM | #3 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Steering Improvements
Run OD gears in the front diff...you'll get more steering that way besides the high clearance knuckles. It will also climb better too.
07-11-2014, 11:16 AM | #4 |
What was already said and a Blue Monkey Ti Steering linkage for SCX, make sure you select the Axial High Steer option Titanium Steering Linkage for SCX10, Blue Monkey RC I un-bent the two end bends slightly to give me a little toe out which also gives more steering. Combine this with OD or UD rear gears, I went front OD and it works great! Or you could do both od and ud gears for even more, but I've found just doing one gearset is enough for me and creates less drivetrain binding and wear. |
07-11-2014, 11:47 AM | #5 |
Rock Crawler Join Date: Apr 2004 Location: Not where I belong.
Its also a good idea to use cvds instead of dogbones since they allow for more travel. Going to a xr / universal setup will give you more steering angle but also a little more width
07-11-2014, 12:05 PM | #6 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
Would it depend on the servo and dual rates? I can understand using universals to get the best radius though.
07-11-2014, 06:02 PM | #7 | |
| Re: Steering Improvements Quote:
07-11-2014, 06:04 PM | #8 |
| Re: Steering Improvements |
07-11-2014, 06:07 PM | #9 | |
07-11-2014, 06:11 PM | #10 |
RCC Addict Join Date: Oct 2012 Location: Norcal
It basically makes the front tires turn faster which will drag the rear tires. Better turning radius will ensue. I personally run OD's up front and UD's in the rear. Makes a big difference in the turning radius and climbs a lot better!
07-11-2014, 06:11 PM | #11 | |
thank you for your replies everyone! | |
07-11-2014, 06:14 PM | #12 |
Just search "bevel gears" on amain and they'll come right up. Underdrive = 43/13 #AXI30402 Stock = 38/13 #AXI30395 Overdrive = 36/14 #AXI30401 CVD's make a huge difference, get rid of those crappy dog bones! |
07-11-2014, 07:25 PM | #13 | |
and what cvd's do i need? I've got a list of stuff that I've gathered from this thread; axial hi-clearance knuckles, blue monkey titanium steering links, cvd's (don't know which though), and bevel gears (need the figure that out ) | |
07-11-2014, 07:26 PM | #14 |
oh wait, i want overdrive gears in the front, got it.
07-11-2014, 07:32 PM | #15 |
People have there own preferences on only running OD in the front and or OD in the front and UD in the back at the same time. If your looking to rock crawl go with both, if you want some speed and bashing go for OD in the front only.
07-11-2014, 08:03 PM | #16 |
my main purpose of getting od or ud gears is for steering, so OD gears JUST in the front and stock in the back will give me better steering, speed and crawling if I'm correct. now i just need to know, what CVD's do i need?
07-11-2014, 10:00 PM | #17 |
ok i decided on the vanquish vvd's (same thing i think) so here is my list of steering upgrades. Axial Hi-Clearance Knuckles (Axial Racing - Axial Hi-clearance Knuckles (2pcs)) Bluemonkey Titanium Steering Linkage (Titanium Steering Linkage for SCX10, Blue Monkey RC) Axial Bevel Gears - Overdrive;36T/14T (Axial Racing - Heavy Duty Bevel Gear Set - 36T/14T) Vanquish VVD's (VANQUISH VVD Axial SCX V2 VPS07031 ax30420 ax30366 ax30464) that should be all i need to get some good steering shouldn't it? |
07-11-2014, 10:11 PM | #18 |
ok i changed my mind on the CVD's, I'm going for RC4WD ones -> RC4WD Extreme Duty XVD Axles for Axial / AX10 / Honcho / Dingo / Rubicon Axles (Scorpion, SCX10) |
07-11-2014, 10:21 PM | #19 |
RCC Addict Join Date: Aug 2009 Location: Earth?
XR10 C's, knuckles, and universals. FTW !
07-11-2014, 10:24 PM | #20 |
Steering Improvements - Similar Threads | ||||
SCX10 Steering Improvements/Rear Steer | BajaBobby | Axial SCX-10 | 18 | 12-25-2012 11:14 PM |
improvements question. | Verdion | Axial AX-10 Scorpion | 4 | 05-29-2011 03:14 PM |
TXT Steering Upgrade -- Easy with big improvements | Rckcrwlr | Tamiya Txt-1 and Juggernaut | 20 | 08-09-2008 05:46 AM |
Cheap Improvements | Toyotawheeler | Axial AX-10 Scorpion | 7 | 05-22-2008 12:29 PM |
simple improvements for a wk | 1TONCHEVY | HPI Wheely King | 7 | 04-07-2008 02:21 PM |
