07-15-2014, 11:19 AM | #1 |
| Feeler: Clocking the motor/transmission
I haven't owned an RC since the '90s, and back then it was a buggy. So bear with me as I get back into it all. So I was flipping my motor/tranny this morning as I've seen done online, when it occurred to me. If I build a little bracket I can clock the driveshafts to centerline and also lower the angles on them. This would also shift the weight of the motor higher, but I'm dropping the battery sideways on the frame rails as well. So I mocked up a bracket from a scrap piece of metal to see what it'd look like. I like it, but the metal wasn't stout enough to do anything with besides a mockup, and I didn't have enough hardware to do it proper like. But I do have some stainless scrap that'll hold fine, and some other stainless scrap large enough I can make a new crossmember out of and lower it a 1/2" or so to help bring the COG down some more. Anyway, just a feeler for thoughts. I did google this idea and didn't find anything on it after a couple of tries. |
07-15-2014, 11:52 AM | #2 |
Pebble Pounder Join Date: Feb 2014 Location: Tracy
Interesting...definetely needs more triangulation "flipoff".....or break it usin like 1/4" alu
07-15-2014, 12:05 PM | #3 |
| Re: Feeler: Clocking the motor/transmission
I thought of doing something like this awhile back... but then I came to conclude that it would be better for my interests, to install a divorce kit instead. ^ motor/primary gear box up front utilizing a transfer gear box centered on the trans skid. Mostly because your current configuration would make it nearly impossible to install an interior. |
07-15-2014, 12:19 PM | #4 |
When I had the body sitting on it and was looking at it as a whole, any sort of interior isn't an option. Not even something level with the windows. But, at this time I'm not looking for a full blown scale rig with interior. I do have a piece of 1mm stainless I can do the same idea as pictured, or some 3mm stainless where I could replace the entire crossmember. A break would be nice, but I'll be whooping it over a vise edge. |
07-15-2014, 01:40 PM | #5 |
Rock Stacker Join Date: Mar 2014 Location: HK
hhumm, it seems you have centered the drive shafts, but to me, the angles were not reduced or may be even increased. Buy looking into the close up photo on the the gear box and motor assembly, you can see the gear box out put shaft position rotated from the left side to the center but a higher position. And the heavy motor was also raised up by quite a lot. Even lowing the battery may not able to compensate the CG shift. Just my thoughts |
07-15-2014, 03:01 PM | #6 |
Rock Crawler Join Date: May 2013 Location: Somewhere in space
This is very strange but interesting, it's something what others come up with. Not bad looking, how's the torque twist? I image that it's not as bad...
07-15-2014, 06:56 PM | #7 |
Good to see creativity but the higher cg of the motor and increased driveshaft angles aren't usually a desired attribute.
07-15-2014, 07:02 PM | #8 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Hmmm...all you did was raise the CG...not good.
07-15-2014, 07:29 PM | #9 |
I dont feel that the COG was raised any substantial amount. Like the stability of a ship, by moving something inboard and raising it slightly has little bearing on the overall stability. The DS angles were not what I had hoped for either. They were nearly the same degree as before, just shifted to a different position. As I said before, it's just feeler concept. Just seeing if this had been tried and the outcome. If I fabbed an entire crossmember and had it slightly lower than what the factory is, it may work for the better. Last edited by Brake Weight; 07-15-2014 at 07:32 PM. |
07-15-2014, 08:22 PM | #10 | |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: Feeler: Clocking the motor/transmission Quote:
07-16-2014, 09:43 AM | #11 | ||
and any raising of the COG becomes a negative. Quote:
Boats or ships sit somewhat below the water line and are further stabilized by the external pressures surrounding the hull. | ||
07-16-2014, 10:02 AM | #12 | |
07-16-2014, 10:40 AM | #13 |
07-16-2014, 10:46 AM | #14 |
Pebble Pounder Join Date: Jul 2013 Location: Candler
07-16-2014, 10:55 AM | #15 |
Ships have nothing to do with crawlers. In a crawler we want the lowest cg possible since we operate our rigs at extreme angles. Many ship captains actually like the cg to be higher than what is mandatory to build the ship. This makes the ship more tippy but makes each tip or sway last longer and be smoother so the ride is more comfortable and less harsh. Two totally different trains of thought. Why does the bend have to be so severe on the plate you made? It seems like it could be bent just enough for the motor to sit right on the frame rail instead of way up in the air like you have it. |
07-16-2014, 10:59 AM | #16 |
That's fair. I'm new again to RC and new here. Figured I'd get flamed and my balls busted somewhat. That's why I asked people that wheel these rigs a lot. Thanks for the comments. |
07-16-2014, 04:49 PM | #17 |
If anything, turn your driveshafts around.
07-17-2014, 10:39 AM | #18 |
Pebble Pounder Join Date: Feb 2014 Location: NH
I think making a lower skid-plate might be the more beneficial way of lessening drive shaft angles. Think of a mildly V-shaped center skid. Instead of lifting the trans up at an angle, imagine sinking the trans down through the middle, while rotating around an imaginary axis which runs through the centerline of the motor. You would sacrifice some clearance, however, but that might be fine for offroad racing or hill-climbs. |
07-17-2014, 11:05 AM | #19 | |
Rock Crawler Join Date: May 2012 Location: Columbus
like this idea make a lil skid plate to protect eather side of the lowered trans | |
07-17-2014, 11:32 AM | #20 | |
Keep it up! | |
Feeler: Clocking the motor/transmission - Similar Threads | ||||
Motor Clocking Jigs | rob_b | EnRoute Berg | 14 | 07-19-2012 10:09 AM |
WK transmission clocking | 47willysbuggy | HPI Wheely King | 5 | 06-10-2010 06:52 PM |
Motor Clocking??? | illz302 | HPI Wheely King | 2 | 08-02-2009 02:54 PM |
