07-17-2014, 07:59 PM | #1 |
Quarry Creeper Join Date: Jan 2013 Location: Long Island, NY
| Got my kit today, started building!
Hey guys! So I decided on the SCX10 Jeep Wrangler kit. I got it earlier today and started building it. While I'm building it, are there are tricks or tips you recommend? I see alot of people run the battery in a different location. Can anyone help me out with this? Thanks! |
07-17-2014, 08:06 PM | #2 |
Newbie Join Date: Jun 2014 Location: Virginia
Following along... I want to do a kit one day as well
07-17-2014, 08:09 PM | #3 |
| Re: Got my kit today, started building!
I've seen people running battery up front, rotating motor plate and some other mods. If you can help me with the above, please let me know! |
07-17-2014, 08:41 PM | #4 |
Pebble Pounder Join Date: May 2014 Location: fernandina beach
I run the Levne Racing battery tray, works well with the Vanquish CMS kit, but be prepared to do some drilling and grinding and bending to make it fit. Once you get it bolted on it makes your front end rock solid, and it has a knock out for a servo winch |
07-18-2014, 04:16 AM | #5 |
I've also seen people doing the mirror mod to the tranny, but I don't understand how to do it.
07-18-2014, 04:58 AM | #6 |
You would just turn the whole skidplate around backwards, it fits either ways. Then reverse the way the engine turns, so it will go forward again. I can't explain why someone would do it though |
07-18-2014, 05:01 AM | #7 |
So you don't recommend doing it? I've heard it helps with the torque twist.
07-18-2014, 08:12 AM | #8 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
I do it on my truck, honestly the way I drive I don't notice much of a difference. BUT, what you have to do is, reverse the skid plate and reverse the transmission output. just flip it around out the other side. This puts the motor over the front tires more, keeping the weight forward. It just changes the COG. Thats all really. whats it mean to mirror the trans? Last edited by robertjpjr; 07-18-2014 at 08:13 AM. Reason: Links |
07-18-2014, 08:25 AM | #9 |
So I have to build my transmission a different way, or just attach the motor plate and motor to it differently?
07-18-2014, 09:18 AM | #10 |
The entire skidplate that the transmission bolts to can be rotated 180 degrees. I always mount mine with the motor up front. Build it exactly as the manual says, just install it 180 degrees from what's shown. Putting the battery pack up front is the best mod you can make out of the box. You have all the required parts in the box, take a look at the G6 kit's instructions and you'll see exactly how's it's done EDIT: intruction links are not valid for whatever reason, can check it out in the gallery. Axial Racing - SCX10 Jeep Wrangler G6 1/10th Scale Electric 4WD - Kit |
07-18-2014, 09:21 AM | #11 |
So that would put the motor on the right and the spur to the front? That's all I need to do?
07-18-2014, 09:49 AM | #12 |
Quarry Creeper Join Date: Jun 2014 Location: Grand Haven, MI
There is a difference between turning the transmission around and mirroring. Mirroring envolves building the transmission with the input shaft coming out of the transmission on the opposite side of what the directions tell you. You will lose the ability to run the gear cover. Here is a thread with a video about it: Scx10 Mirror Transmission mod Last edited by 1967Typhoon; 07-18-2014 at 09:53 AM. |
07-18-2014, 09:56 AM | #13 |
Rock Stacker Join Date: Jul 2009 Location: colorado springs
Mirroring the trans does not simply mean turn the trans the other direction. If you want to mirror the trans you must build the trans differently. If you do this you will not be able to use the spur gear cover. I'll do what i can to find a good Tech thread later today for ya Edit: Looks like i was 7 mins to slow lol! Last edited by cykb4117; 07-18-2014 at 09:58 AM. |
07-18-2014, 10:50 AM | #14 |
Thanks guys! So I just need to open my trans case and make the shaft come out the other side? Just got back from my LHS with a Castle Creations Sidewinder ESC and a Hitec 5646 waterproof servo! Also ordered a Holmes 27t motor this morning. |
07-18-2014, 01:39 PM | #15 |
| Re: Got my kit today, started building! Yep, there's a plastic plug that pops out of the back. Your topshaft will stick out there, and the plug will go back in the other side. But like them other dudes said, you can't run a cover. A motor mount will flip over backwards, though, but not a spur gear cover.
07-18-2014, 02:02 PM | #16 | |
| Re: Got my kit today, started building! Quote:
07-18-2014, 04:29 PM | #17 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
Install the driveshafts with the splined half attached to the transmission. This will save the splines. You can also beef up the stock shafts by inserting a plastic rod inside of the splined shaft. Preferably, you'll want steel driveshafts.
07-18-2014, 04:34 PM | #18 |
Unlike that other battery tray that you have to hack to install, I really like this one...and it bolts right in!! Front Tray Axial RC Crawler Scale Honcho Dingo Rubicon JK SCX10 1 10 Truck | eBay |
07-18-2014, 04:50 PM | #19 | ||
07-18-2014, 05:56 PM | #20 |
This is what the Levne Racing tray looks like, it puts the battery low. I had to bend mine a bit right above where the battery sits to make it fit right, and its bolted in, NOT screwed The plate on the left side holds the esc and bec, everything is bolted down and/or zip-tied, I hate that sticky tape. The right side is the Vanquish side rail mount which holds a Traxxas radio box. Hope it helps... |
Got my kit today, started building! - Similar Threads | ||||
Started building my crawling course today! | AXLE 69 | General Crawlers | 21 | 10-13-2013 06:34 PM |
Started Building My TF2 | markturbo | RC4WD Trail Finder 2 | 14 | 03-10-2013 05:37 PM |
Started building my home course | mr.freeze | General Crawlers | 18 | 12-02-2009 02:07 PM |
started building my kit, and already have an issue :( | mr_manny | Axial AX-10 Scorpion | 9 | 03-30-2008 09:13 PM |
Started Building My First TLT | xjrrrdx | Tamiya TLT Crawlers | 18 | 03-24-2007 10:05 AM |
