07-25-2014, 08:35 PM | #1 |
Newbie Join Date: Jun 2014 Location: USA
| Sparks from 27T Motor
Hi guys, I bought a used SCX10, and it came with the stock 27T motor. Today I noticed that there are sparks shooting out from the motor when it is in full throttle. Inspecting the motor more closley, I noticed that there is broken brushes; I only found 5 complete ones, and the others are completely broken; as in the below pictures What would cause this, so I can avoid it in the future, the gearing is the stock one 20/87 I believe. Thanks in advance, |
07-25-2014, 10:17 PM | #2 | |
| Re: Sparks from 27T Motor Quote:
there's only two brushes per motor !? pictures wouldn't load for me things that can cause damage to brushes... 1. heat (over geared/full throttle-jack rabbit starts) 2. impact (jumping houses) 3. contamination(debris in motor) 4. commutator run out bad/bad bearings-bushings 5. defectively mfgr'd brushes from the start besides it's windings... what motor do you have ? | |
07-25-2014, 11:10 PM | #3 | |
If you click on the links, wouldn't they open the images? http://postimg.org/image/fz0t1j7h3/ http://postimg.org/image/q0bsl4759/ | |
07-25-2014, 11:26 PM | #4 |
Those are blades on the internal cooling fan...lots of times running in loose gravel/dirt/sand will cause them to break off when hit by debris...dont know how critical they are for that cheap motor..sparks could indicate issues with worn bearings which could also cause broken blades from fan contacting motor housing
07-25-2014, 11:51 PM | #5 | |
The motor sometimes gets hot, so I don't know if this is due the missing blades, only 5 blades still available. I already ordered another one along 55T one; I know they are cheap, however, I am trying to find the best 'T'; then I would get a better one. For 27T, what gearing is advised, mainly for bashing and crawling. Am not looking for much speed. Thanks, | |
07-25-2014, 11:57 PM | #6 |
RCC Addict Join Date: Jul 2013 Location: Planet Earth
For a 27t motor try a 16 tooth motor pinion with the stock 87 turn spur gear...A 55 turn will be very very slow and you won't get up many hills or through soft stuff like mud or sand..I don't recommend it personally...if you have to, try a 35 turn but I recommend a 27 turn especially if you are using a 2s battery. The 16 tooth gear will also help you with cooler temperatures Last edited by 6sharky9; 07-26-2014 at 12:02 AM. |
07-26-2014, 12:13 AM | #7 |
Rock Crawler Join Date: Apr 2009 Location: bend
16/87 sounds good... final ratio about 5.5 to 1 is what i like to run.
Sparks from 27T Motor - Similar Threads | ||||
Brushed motor sparks | Hoser1869 | Electronics | 15 | 12-13-2013 09:04 PM |
27t motor | dirtyflakes | Formula Offroad | 6 | 08-30-2011 06:49 PM |
