Thread: question about centering axles
Old 08-17-2014, 12:16 AM   #1
Default question about centering axles
guys how do yall get yalls wraith axles centered under the scx10 chassis?
for some reason i cannot get them centered.
i have the wraith skid plate.
can anyone give me som tips?
__T__ is offline   Reply With Quote
Old 08-17-2014, 12:49 AM   #2
Default Re: question about centering axles
What are you having problems with exactly, some pics might help but if your using the stock link mounts and your links are even length side to side you should be good.
greenjk is offline   Reply With Quote
Old 08-17-2014, 01:55 AM   #3
stk
You can hook up 3 of the links and not the 4th?
You may need to use different length links.
stk is offline   Reply With Quote
Old 08-17-2014, 03:16 AM   #4
ill get pics tomorrow
Old 08-17-2014, 08:32 PM   #5
about as close as i can get the front centered.the rear is fine.just cant get the front to center up.
about had it with this little truck.
what the crap am i doing wrong?
Old 08-17-2014, 09:48 PM   #6
Looks like your upper link on the left (in the picture ) is longer than the right. Try unbolt in it from the chassis by the trans and see if that would alow it to center.
Or its that the right is longer pulling it over to the right side. I would remove one at a time and see what happens.
AsILayDying is offline   Reply With Quote
Old 08-17-2014, 10:08 PM   #7
stk
I would agree that the upper links dont match.
Didn't mix up a link with the tie rod by any chance?
Old 08-18-2014, 04:36 AM   #8
if i do what yall said above then the other side goes out of wack
Old 08-18-2014, 05:38 AM   #9
Looks like the chassis is too wide, what happens if you take the shocks off. Can you shorten the crossmembers and pinch the front in.
Old 08-18-2014, 10:10 AM   #10
I don't think you want to run a Wraith skid, it makes the chassis too wide and the shocks are pinched. Try it with an SCX skid and cross members.
Ty@Tekin is offline   Reply With Quote
Old 08-18-2014, 02:46 PM   #11
As Ty said use the scx skid and braces, I 3 linked the front and rear of mine. I did u build thread of how I did it. Just mirror ur trans and either bend the 1 upper link or 3 link and panhard it
SkyJacked is offline   Reply With Quote
Old 08-18-2014, 05:52 PM   #12
Nothing wrong with using the wraith skid, you just need to narrow the front and rear of the chassis for shock and turning clearance.
question about centering axles - Similar Threads
centering pins for yota axles? twilight General Scale Talk 7 03-23-2014 09:53 PM
Servo Centering baddley Axial Wraith 10 12-16-2012 10:15 AM
dual centering dx-6 joesbruiser Electronics 8 04-15-2007 01:44 AM
self centering potentiometer powertuned Electronics 0 05-13-2005 03:37 PM
