Thread: Driveshaft with steep angle capability's
Old 08-19-2014, 11:38 PM   #1
Question Driveshaft with steep angle capability's
i just installed gmade zero 104mm into my dingo, they are super smooth shocks. But now my driveshafts are binding. Whats the driveshaft that fits dingo wheelbase that can take a worse angle than the stock wb8 driveshaft?
Brehrocks is offline   Reply With Quote
Old 08-20-2014, 02:50 AM   #2
Default Re: Driveshaft with steep angle capability's
You installed shocks for a wraith,should have went with 94mm for a scx10. Now you need different upper link's to adjust for the extra shock length.
realsickclown is offline   Reply With Quote
Old 08-20-2014, 05:12 AM   #3
I have Gmade zero 104mm shocks in my scx10 too. I installed a shock lift/lowering kit and angled the shocks so the ride height is the same as with the 93mm shocks. This is what I have...Axial SCX10 Lift Kit or Lower Kit Fits Rubicon Honcho and Dingo | eBay
Johnnysplits is offline   Reply With Quote
Old 08-20-2014, 06:17 AM   #4
^ I did the same to both of my trucks. Helps keep the COG lower also.
Sent from my iPhone
jason02ws6 is offline   Reply With Quote
Old 08-20-2014, 06:27 AM   #5
junfaq shafts are great in this case
Ohioskills is offline   Reply With Quote
Old 08-20-2014, 06:50 AM   #6
As said above, you purchased the wrong shocks, 93mm is what you need for the SX10. So pick up one the of the "lift" or "droop"kits that bolt to the shock hoops, install and use it as a lowering kit......or get the correct shocks.
One of the guys in our club runs the 103" Gmade shocks with the droop kit and he really likes that setup.
HDMM is offline   Reply With Quote
Old 08-20-2014, 11:45 AM   #7
my driveshafts are right on the edge of binding though, i can still drive it on the rocks but if i pick it up the axles start to hop due to the driveshafts.
Old 08-20-2014, 11:59 AM   #8
You're using the stock shafts right? Try the Junfac's. I bought the ones that fit the wraith for my honcho. So far, I'm very happy with them. There is one design flaw they have though, which isn't an issue unless you're running over very rocky areas...the snap rings that capture the joint pins are on the outside of the housing, which can pop off while running over rocks. I don't have that issue here on the west coast of FL. The only rocks around here are used for landscaping lol
Old 08-20-2014, 12:05 PM   #9
Toss some limiters inside your shocks so it doesn't droop far enough to bind the drive shafts.
Ty@Tekin is offline   Reply With Quote
Old 08-23-2014, 08:26 PM   #10
I have 110mm kings on my scx ... Runnin a set of junfac drive shafts .. ABSOLUTELY NO BINDING ISSUES
Purptr8r is offline   Reply With Quote
Old 08-23-2014, 08:29 PM   #11
I also run a wraith tranny which technically makes the shaft angle steeper .... I recently switched to 100mm kings for more of a c3 truggy look after buying a tundra hard body
Old 09-27-2014, 11:32 AM   #12
I'm running 100mm kings on my scx10. MIP driveshafts and stock scx10 tranny.
FlexinFL is offline   Reply With Quote
Old 09-27-2014, 12:42 PM   #13
I run 100mm kings with stock everything. And no issues. Maybe it's just the 4mm difference.
cotyhamlett is offline   Reply With Quote
Tags
bind, dingo, driveshaft, scx10
Driveshaft with steep angle capability's - Similar Threads
Best driveshaft for steep angles Propane General Scale Talk 11 03-10-2012 10:14 PM
Rear motor stalls when climbing steep angle ik632 Axial XR10 6 02-11-2012 08:23 PM
driveshaft angle scx10mudder Axial SCX-10 4 03-28-2011 11:07 PM
Driveshaft angle? jgammill Axial SCX-10 6 03-01-2011 01:23 PM
how steep of angle can you crawl? ykcor General Crawlers 48 11-11-2008 11:51 AM
