Thread: Scx10 throttle hung in neutral
Old 10-29-2014, 08:08 PM   #1
Default Scx10 throttle hung in neutral
My scx10 with a hh brxl and crawlmaster 13t was running fine until it decided to have full throttle while in the neutral position on my controller? What causes this? If I hit reverse it will stop but as soon as I let off its full throttle.
Stangman92 is offline   Reply With Quote
Old 10-29-2014, 08:22 PM   #2
Default Re: Scx10 throttle hung in neutral
Recalibrate esc to the rx/tx
jeepscx10 is offline   Reply With Quote
Old 10-29-2014, 08:56 PM   #3
Your transmitter got set to normal instead of rev on channel 2?
robertjpjr is offline   Reply With Quote
Old 10-30-2014, 12:07 PM   #4
I tried recalibrating it does the same thing and doesnt beep just show the lights. Its a sprektrum dx3c transmitter
Old 10-30-2014, 12:17 PM   #5
I recently had a problem getting one of my Castle ESCs to calibrate to a Spektrum radio, I had to downgrade the firmware to the previous version to get it to calibrate properly.
svt923 is offline   Reply With Quote
Old 10-31-2014, 08:28 AM   #6
What radio do you have? Did you check to make sure your trim didn't get changed on accident?
spookyseven is offline   Reply With Quote
Old 10-31-2014, 03:00 PM   #7
Spektrum dx3c no the trim hadnt changed I messed around with it and can figure it out. May have to send it in I just dont understand how it ran fine one minute then wot the next.
Old 11-01-2014, 09:44 AM   #8
Try reversing channel 2 on the radio.
novarider is offline   Reply With Quote
Scx10 throttle hung in neutral - Similar Threads
SCX10 Throttle Randomly Reversed... binns.mark Electronics 1 09-14-2014 12:48 PM
Brand new scx10 goes into reverse and full throttle rev when radio off? milestone Electronics 18 10-03-2013 01:54 PM
New scx10 throttle glitches ?? matt_22 Axial SCX-10 14 02-10-2013 12:54 PM
New axial scx10 having glitching throttle issues matt_22 Electronics 3 01-30-2013 11:55 PM
Axial scx10 throttle issue or normal? Jake1715 Newbie General 4 07-16-2012 01:22 PM
