12-15-2014, 10:55 AM | #1 |
Newbie Join Date: Nov 2014 Location: bc
| 90mm vs 100mm shocks
whats the go to shock for performance and scale looks. and whats the optimum length to maximize my g6's abilities.
12-15-2014, 12:13 PM | #2 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
| Re: 90mm vs 100mm shocks
For my SCX-WRATH I went ProLine Power Stroke front all around. For my 4X4X4 Wraith, I use the same but rear all around
12-15-2014, 02:16 PM | #3 |
Quarry Creeper Join Date: Aug 2014 Location: San Diego
| Re: 90mm vs 100mm shocks I use 100mm Kings all the way around. |
12-15-2014, 04:14 PM | #4 |
Newbie Join Date: Oct 2011 Location: Cincinnati
I also run the slash rear powerstroke shocks all the way around my scx10
12-16-2014, 03:58 PM | #5 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
Powerstrokes are some of the smoothest shocks money can buy . But the dual rate shocks from rc4wd have the looks.
12-16-2014, 05:42 PM | #6 |
Newbie Join Date: Dec 2012 Location: Minerva
On my g6 I use rc4wd super lift 90mm mounted upside down with just enough 7000 weight diff oil to dunk the piston when fully depressed. The thick oil provides enough friction to make it run great and not bounce around. Sent from my iPhone using Tapatalk |
12-17-2014, 12:28 AM | #7 |
Newbie Join Date: Nov 2014 Location: Calgary
I hear a lot of hype about the king shocks for performance and looks. I personally run a 108mm aluminum shock on mine that I bought on Amazon. I can definitely say the overall flex improved with the longer shocks because there is more travel. Jeeping is life... The rest is just details. Last edited by DrWardner; 12-17-2014 at 01:50 AM. |
12-17-2014, 08:55 AM | #8 |
Kings are like butter. $45 per set on ebay with free shipping.
12-17-2014, 09:45 AM | #9 |
| Re: 90mm vs 100mm shocks |
12-17-2014, 11:25 AM | #10 |
My shocks be like, I can't believe it's not butter.
12-17-2014, 12:44 PM | #11 |
12-18-2014, 08:35 PM | #12 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
| Re: 90mm vs 100mm shocks I run rear shocks off a stadium truck on all 4 corners with front springs off a stadium truck on all corners. It get great articulation and a low slung height Sent from my iPhone using Tapatalk |
12-19-2014, 12:36 PM | #13 |
nice,so between proline and king we've got nice smooth shocks vs slightly longer scale shocks big question is is having smooth consistant shocks more benefitial than having longer shocks that provide more articulation?
12-19-2014, 12:46 PM | #14 |
I heard less is more. As in less articulation, more something else.
12-19-2014, 03:46 PM | #15 |
Newbie Join Date: Oct 2014 Location: Loomis-West Sacramento
im running the losi 4" crawler shocks. been running them a couple weeks, not a drop of shock oil leaked, and I did nothing to help the seals or threads, just assembled. I have to say they are very smooth, a couple mm's shorter than stock wraith shocks, which is what i was running on my scx deadbolt. There is no comparison between stock axial shocks and good quality aftermarket shocks. Kings, Losi's, proline's, and a few others are a great upgrade. I have ridiculousness flex in crazy off-camber situations, I think i need slightly heavier shock oil... anyhow, whatever your choice, you should be happy
06-04-2015, 06:27 AM | #16 |
Newbie Join Date: Jun 2015 Location: Australia
I have a new scx10 G6. Can I go to 100mm (or longer) shocks without affecting driveline angles too much, or does something else have to change?
06-04-2015, 07:49 AM | #17 |
Rock Stacker Join Date: Mar 2014 Location: Albuquerque
@Tom95YJ could we get a measurement on those shocks? Trane |
06-04-2015, 07:58 AM | #18 |
Pebble Pounder Join Date: Feb 2015 Location: Carson Valley
I use the 100mm Kings and dont have any issue with drive line angles. It all about the preload setting....keep it at a lower static height to get more droop. Measurements for the Kings are 100mm uncompressed and 70mm compressed.(if I remember right) |
06-04-2015, 08:31 AM | #19 |
RCC Addict Join Date: Feb 2012 Location: UK
I run stock Axial shocks. Each with 30wt oil that sits all over the axles and the floor when stood. Ride is bouncy....very bouncy. |
06-04-2015, 09:36 AM | #20 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
just my 2 cents, the lower you rig the better it will perform. I run gmade 103 but use a lift kit to lay them down and lower the truck. My scx is a multi purpose rig, but runs in trail class comps alot. Stability is a must, I cant afford to be on my roof ever. the taller a rig is the more it will flip.
90mm vs 100mm shocks - Similar Threads | ||||
120mm shocks vs 90mm and 100mm | YelloTJ | Newbie General | 2 | 01-10-2010 06:20 PM |
100mm scale shocks or 90mm??? | jd267 | 1.9 Scale Rigs | 5 | 12-07-2008 09:16 AM |
