Originally Posted by stopmojim I'm using the Howler Customs battery plate with 1.9 tires and wheels with stock steering and a huge 5000 mah 2 cell. I have no issues with binding or rubbing the tires against he battery plate.
I could have made the battery plate myself, but 20 bucks shipped with all the kinks worked out and a nice factory stamped look made it a no brainer for me. The only issue I see is that I will need special tabs added to metal sliders so I can still use the mounting holes the stock sliders provide.
Here's a couple of pics to show battery placement.
Here's a shot to show the angle of the battery on the bracket. It's not all the way down, providing a bit of space for the tires.
This is where it mounts in the front. It uses the same two holes that hold the receiver box in place. The spacers are the same used in the forward battery mod.
Here I've turned the front wheel in all the way. Even with the MT Baja Claws TTC tires, which are the same height as stock tires but much wider, there is plenty of room between the tire and the battery plate. |
That's the cleanest best tire clearance, great price, looking cross chassis battery mount plate that I've seen!
Originally Posted by TacoCrawler ...alternative
and the lowest possible COG
saddles made from scrap 1/8" lexan sheet
lexan heated, ends angled upwards slightly
Then mounted directly atop the stock slider using original screw holes/mounts.
Counter sunk the screw heads into the lexan saddles,
I used slightly longer machined screw with a nylock nut.
velcro buckle straps secure the batteries to the saddles.
dual 3S 2200's connect using parallel harness (harness mia)
also did this with my homebuilt sliders...
even manage to run a dinky interior on my honcho
and clears my 2200's... but just barely. |
Another nice option and very cleanly done.
Originally Posted by Toykid Here is how I have done it. I made a simple mount that used the stock tray parts and positions the battery as low as possible behind the front fenders. I just fitted it tonight and will be giving it, it's first test tomorrow out at Vasquez Rocks. |
Very nice and clean too, only part I'd skip the plastic outline piece and bolt the battery plate straight to your plastic peice with countersunk screws.
Originally Posted by sdmf
If I didn't have so many beers that night, it would have taken under an hour to make the plate. I used 20g duct sheet metal, made two holes with a tab to mount on the cross brace, used the 2 servo mounts in the spare parts. I still have to trim off the excess, but it cost nothing to do. |
I made a tray from aluminum and mounted it much like this, but mine is only as wide as the outside of my chassis rails. I get lots of steering and running stock shocks with rubber bumpstops removed almost every battery larger than 2200mah 3s1p will rub at full lock turn and bump compression.
