03-27-2015, 11:26 AM | #1 |
Newbie Join Date: Feb 2015 Location: texas
| Help needed!!
Ok I switched the front of my scx10 falken edition from a three link to a four link. Now my servo horn hits bar that I was going to use to move the battery tray to the front. I took it apart and tried again and it still hits the horn. Did I do something wrong? Sent from my iPhone using Tapatalk |
03-27-2015, 11:34 AM | #2 |
Newbie Join Date: Feb 2015 Location: Chicago
| Re: Help needed!!
Remove the two screws and take it out
03-27-2015, 11:45 AM | #3 |
| Re: Help needed!!
I figured that. I was wondering if there was something I missed. Guess I'll keep the battery in the back Sent from my iPhone using Tapatalk |
03-27-2015, 11:52 AM | #4 |
| Re: Help needed!!
Put your battery across the chassis behind the shock towers. Weight is much further forward, and spread even left to right. DT's WranglAR - Just another Jeep Or make a plate to move the servo back a little. Either way you can keep that crossbar for chassis support. |
03-27-2015, 02:59 PM | #5 |
| Re: Help needed!!
use a dremel to make some clearance
03-27-2015, 04:46 PM | #6 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
| Re: Help needed!!
Lay the old three link in there and see if you made the 4 link too long. Is the axle clocked further forward than it was before? The Falken edition has a 12" wheelbase, stock.
03-27-2015, 05:10 PM | #7 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Help needed!!
Did the 4-link conversion tilt the front axle or extend the wheelbase up front? Did you change the servo plate during the conversion or make any other changes? Looks like you've either tilted or shifted/slid the axle forward or slid the servo forward, if you had clearance before the conversion. Last edited by Eric0424; 04-02-2015 at 09:18 AM. |
03-27-2015, 07:32 PM | #8 |
Rock Crawler Join Date: Oct 2006 Location: New Tripoli, PA
| Re: Help needed!!
My g6's servo hit the same brace, it is a known problem when 4-linked, just remove it or dremel as others stated. Cheers, Wade |
03-27-2015, 08:02 PM | #9 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
| Re: Help needed!!
Use a dremmel to clearance it . Shave the crossmember, it makes the front of the frame stronger than removing the frame brace up front.
Help needed!! - Similar Threads | ||||
Help needed | 02tac | Non Crawler RC's | 0 | 02-25-2011 10:31 AM |
