02-23-2015, 09:42 AM | #1 |
| DT's WranglAR - Just another Jeep
I have had this chassis, transmission, and motor sitting around for a few years now. I have wanted to do an SCX frame on AR60's ever since I saw Bender's Wroncho. Also Wraith based rigs on 2.2's seem to be the go to for guys around here. I don't want to be the hold up on the trail, so if you can't beat 'em, join 'em. To not insult to the Wroncho guys I will call this rig the WranglAR, since it's just another Jeep Rubi build. The starting point: So I put together a little RPP order to get this project rolling. The WranglAR parts list: SCX Frame Robinson Geared Transmission Brood 30T HHK-GR in Epic oval brush can Castle BEC Holmes Hobbies BRXL Hitec 7950 Axial HD gears OD\UD Hand Bros. CMS RC4WD Front Bumper (this may change) RC4WD Rear Bumper (this may change) Axial AR60 Axle Housings Beef Tubes - both axles MIP Spline Set Center CVD Kit STRC Aluminum Internal Diff Holders STRC Front Shock Towers STRC Rear Shock Towers STRC Truss - Front DLUX Truss - Rear Fast Eddy Axial SCX-10 Bearing Kit Axial Icon 61-90mm Aluminum Shocks Axial Scale Rock Rails Axial Jeep® Wrangler Unlimited Rubicon Body Knight Custom Jeep Grill Knight Custom Fender Wells - Front Knight Custom Fender Wells - Rear HeyOK 4A Relay Winch Controller KMS Winches K3 Servo Winch SSD Scale Hawse Fairlead VP Poison Spyder JK LED light bar mount VP Rigid 6" LED light bar VP Rigid 1" LED light bar Black VP Transmission Case VP Motor Mount\guard VP Wraith Panhard Kit VP Wraith Scale Knuckle VP Wraith Scale Chubs VP Wraith Shock Link Mounts VP Wraith VVD V1-HD VP Wraith Titanium Tie Rod VP SCX10 / JK 4 Links Locked Up FI Spools RC4WD Poison Spyder Wraith Diff cover Axial 2.2 Maxxis Trepadors Gear Head RC 2.2 Trail King Wheels Crawler Innovations 5.5 Double Deuce Foams Last edited by DickyT; 02-27-2015 at 01:13 PM. |
02-24-2015, 07:18 AM | #2 |
I wanna be Dave Join Date: Dec 2009 Location: Lady Lake, Fl
| Re: DT's WranglAR - Just another Jeep Quote: |
02-24-2015, 08:00 AM | #3 |
| Re: DT's WranglAR - Just another Jeep Thanks Bill I have to wait for the parts to show up... Current delivery date is next Monday. Believe me, I would love to be wrenching on it this week. I'll probably have to take a rain check on the 7th, after buying all these parts I won't be able to afford the travel costs |
02-24-2015, 09:06 AM | #4 |
A few more items have been added to the parts list. This morning I ordered a Waterproof BR-XL because I know I will need something more robust then an FXR when the HEAT of summer is kicking down here. VP transmission case, my current case has 2 stripped holes and has been in 4 different rigs over the last 6 years, it's time. And finally a VP motor mount\Gear Guard. My current plate has so much material ground off of it for squeezing it in 2.2s and it is just beat up after 6 years of use and abuse. This will handle hot temps much better than an FXR, plus I can run 6s if I feel like frying a motor for some extreme fun before motor death, and had a far superior drag brake Black was on back order, so I went with Silver Silver was on back order, so I went with Black I'll get my actual pics up when things start arriving, but felt my thread was lacking photos due to everything in the mail, so I added some from the vendors I ordered from Last edited by DickyT; 02-24-2015 at 09:16 AM. |
02-24-2015, 07:04 PM | #5 |
I'll be going with the spare parts bin battery mount. I found an ax\scx tray that I had never used in an old junk box, and pulled the servo mounts and screw retainers off the parts tree from my Yeti kit. I just need to track down my bag of Velcro straps and it should hold this zippy 5000 mah 3s pack nicely. And that about does it until parts show up later this week and next week. |
02-24-2015, 07:23 PM | #6 |
Well, I wasn't totally sold on that solution. I wanted some sort of hard stop at the bottom of the plate in the event of Velcro strap failure. How a Velcro strap that is protected inside the chassis would fail? I don't know, but if it can be broken, I will find a way. So I dug a little more in the junk box and found some m3x12 studs, screwed them into some traxxas rod ends, then used them to mount the plate to the servo mounts. This will only allow the battery to slide out the sides now, forcing it's way through the body in the event of Velcro failure due to ham fisted driving! |
02-24-2015, 08:56 PM | #7 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
Nice parts list. Looking forward to seeing this build progress.
02-25-2015, 01:20 AM | #8 |
Rock Crawler Join Date: May 2012 Location: Upland
What body are you running? Wondering how the velcro works Sent from my SPH-L720 using Tapatalk |
02-25-2015, 06:00 AM | #9 | |
I'll be using the Rubi Unlimited. I'm not sure the Velcro body mounts will stay. They are from the Newbright JK body I originally had on this chassis a few years ago. | |
02-25-2015, 09:37 AM | #10 |
I forgot an important item on initial order day, Beef tubes! Just ordered 2 sets so both axles get some beef tube lovin'. In a month or so when my wallet has recovered from this all, I will start thinking about a lighting solution, but the budget is shot for now. I may have some old drift car lights I can put in the buckets for now though. I'll have to search the spares box in the garage. |
02-25-2015, 05:15 PM | #11 |
Rock Stacker Join Date: Jul 2010 Location: Australia
Subscribed |
02-25-2015, 05:43 PM | #12 |
Pebble Pounder Join Date: Feb 2014 Location: Hampton Roads
| Re: DT's WranglAR - Just another Jeep This body is from Newbright RC? looks really nice
02-25-2015, 06:07 PM | #13 |
| Re: DT's WranglAR - Just another Jeep Yes, that was a Newbright body. Thanks, I had a lot of work into that rig. If you want to check it out, you can read the build here: DT's SCX Jeep JK |
02-27-2015, 01:13 PM | #14 |
Hi, My name is DickyT and I'm an addict... I have not received any of the parts to start the build yet, but blew the next few weeks lunch money at RPP today HeyOK 4A Relay Winch Controller KMS Winches K3 Servo Winch SSD Scale Hawse Fairlead VP Poison Spyder JK LED light bar mount VP Rigid 6" LED light bar VP Rigid 1" LED light bar Black I still need to swing by my LHS and get some paint and wire to run motor leads. Last edited by DickyT; 02-27-2015 at 01:16 PM. |
02-27-2015, 07:30 PM | #15 |
Rock Crawler Join Date: Mar 2011 Location: USA
These pics might help a little for a mount for the K3 SW 180 ,,Thank you Robert |
02-27-2015, 08:00 PM | #16 |
Thanks Robert, I was going to rear mount it and run a crazy tube to the front, but I like that MUCH better! More weight over the front axle too! Time to dig for that 1/8"X1" alu bar I know I have somewhere, or pick up some more.
02-28-2015, 09:58 AM | #17 |
| Re: DT's WranglAR - Just another Jeep You are welcome .This setup worked good ,I had 2 fairlead mounts on it ,One right in front of winch other on bumper ,,Thank you Robert |
02-28-2015, 04:46 PM | #18 |
| Re: DT's WranglAR - Just another Jeep |
02-28-2015, 05:39 PM | #19 |
02-28-2015, 07:49 PM | #20 |
DT's WranglAR - Just another Jeep - Similar Threads | ||||
DT's Viper II | DickyT | Videos! | 13 | 06-06-2012 03:33 AM |
DT's SCX Jeep JK | DickyT | Axial SCX-10 | 124 | 06-13-2011 08:08 AM |
DT's UGC Viper | DickyT | Axial XR10 | 943 | 04-20-2011 05:45 PM |
DT's FF-4 build | DickyT | Axial AX-10 Scorpion | 91 | 06-23-2010 07:34 PM |
Got a case of the DT's | Duspan | Losi Micro-Rock Crawler | 4 | 01-11-2010 02:15 PM |
