04-05-2015, 05:39 AM | #1 |
Newbie Join Date: Apr 2015 Location: UK
| towing
Hello, does anyone know the best and quickest way of disengaging the transmission on an scx10 so it can be towed? Thanks for any info. |
04-05-2015, 06:02 AM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: towing
Pull the rear driveshaft at the axle if you're lifting the front to tow or pull both drivehsafts at the axle if you're pulling with all four wheels on the ground. Put the driveshaft halves in the tow vehicle or in the back of the one being towed.
04-05-2015, 06:08 AM | #3 |
Rock Crawler Join Date: Oct 2013 Location: Wiscasset, ME
| Re: towing
Remove your pinion gear. You'll still have the drag of the drive train, but its better than removing driveshafts. IMO
04-19-2015, 07:09 PM | #4 |
Newbie Join Date: Oct 2014 Location: DFW Texas
| Re: towing No need to tear into a axle to free wheel it, its 100x easer to pull the pin out of the drive shaft at the axle side and pull it off and tie it to. The frame and off you go, no there is no easy way to disengage the drivetrain , unless you get a wraith transmission, even then you can only disengage either the front or rear can do both at the same time.
04-19-2015, 07:14 PM | #5 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Dig
04-19-2015, 07:48 PM | #6 |
Rock Crawler Join Date: Jan 2004 Location: Round Rock, TX
| Re: towing
I'm trying to understand the purpose. Scale vehicle recovery?
04-19-2015, 08:09 PM | #7 |
Rock Crawler Join Date: May 2009 Location: Texas
| Re: towing
Trailer it bud Because not only will you have to disengage the shafts but also the drag link on servo. |
towing - Similar Threads | ||||
Tamiya Unimog for towing? | golfmech | Newbie General | 0 | 01-03-2014 02:41 PM |
Towing CK? | myers137 | HPI Wheely King | 2 | 02-24-2012 12:42 PM |
Towing skillz | microgoat | Chit Chat | 2 | 12-02-2009 05:54 AM |
Scale towing accessories? | NickRummy | Scale Accessories | 9 | 03-30-2007 06:18 AM |
Towing and D.O.T | shipwrek | Chit Chat | 0 | 07-20-2005 11:56 AM |
