Thread: Xr steering mod
Old 04-27-2015, 09:38 PM   #1
Default Xr steering mod
I've done some searching and before I placed orders I figured ask
Is there any other better or cheaper options to get splined tubes other that burley tubes? I'd like to keep stock track width
Dodgevanman is offline   Reply With Quote
Old 04-28-2015, 06:43 AM   #2
Default Re: Xr steering mod
The stock xr plastic c's will push right on the scx axle case with no modding. The axle case already has a large spline at the top and bottom. Give it a try.
KBrog is offline   Reply With Quote
Old 04-28-2015, 11:20 AM   #3
Jeckler's Avatar
I thought a V had to be ground into the stock housing"s "spline" if splined tubes aren't going to be used?
The nice thing about the splined tubes is strength and the ability to further clock the chubs.
And doesn't this mod still push the axles out about a half an inch, no matter which way you go?
Jeckler is offline   Reply With Quote
Old 04-28-2015, 11:42 AM   #4
Rcbros offer stock width tubes but you have to cut the axle housing and drill a couple holes.
novarider is offline   Reply With Quote
Old 04-28-2015, 12:43 PM   #5
I'm debating on doing stock width or xr widith I'm ok with alittle more tracking width
Old 04-28-2015, 01:28 PM   #6
The xr mod does add just a little bit of width but nothing to worry about. I did not have to grind a V on either of my rigs when using xr plastic c's. Maybe you will if using alm c's.
Old 04-28-2015, 01:49 PM   #7
Guess I'll pick up some plastic C's and do some playing
Xr steering mod - Similar Threads
new steering on the new PRO/ OTA steering mod axialjeepster AxialJeepster Losi Mini-Rock Crawler 4 10-14-2012 01:03 AM
Xirtic + JP High Clearance Steering Mod on Mod JeffK11 RC4WD Bully 1 02-01-2012 09:55 AM
R1 STEERING MOD maybe? cul8tr G-Made Crawlers 3 02-06-2011 01:40 PM
Front Dig Mod,steering mod & pushbar TheButcher69 General Crawlers 1 11-06-2006 06:32 PM
where is the steering mod 12flex General Crawlers 1 05-08-2006 09:34 PM
