05-01-2015, 04:12 PM | #1 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Hubs required???
Are the aluminum hubs required for a set of RC4WD RaceLine aluminum beadlock wheels on an SCX10 with stock axles? If it makes a difference I have the STRC aluminum goodies on the outside ends of the axles.Really wanting the RaceLine's without the extra cost of the widening hubs. Hubs required??? |
05-01-2015, 06:27 PM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Hubs required???
Which Raceline wheels (part/model number)?? The 1.9 inch "Monster" I'm looking at don't need a separate hub, just the 12mm hex (AX30427) that comes with the SCX10. This set is said to have a 12.8mm negative off-set which is nearly the same as the stock wheels at 12.19mm (just .61mm or .024" difference). You shouldn't have a problem mounting them. However, "off-set" is not the proper term for the measurement they're giving. Backspacing is the proper term for that measurement. The negative off-set is actually around .95mm if my math is right. Last edited by Eric0424; 05-01-2015 at 06:41 PM. |
Hubs required??? - Similar Threads | ||||
When a BEC is required | gfmucci | Electronics | 67 | 05-03-2015 11:16 AM |
Lathe not required | crawlerhawk | Tools, and Procedures | 15 | 08-09-2012 11:29 AM |
help required,,,, | b16bazza | Axial AX-10 Scorpion | 7 | 02-17-2009 06:30 PM |
