05-02-2015, 07:44 PM | #1 |
Quarry Creeper Join Date: Apr 2015 Location: Georgia
| Shock oil
The kit came with 30 but it feels stiff would 10 be alright and with the shock spacers would you cut them down
05-02-2015, 08:38 PM | #2 |
Pebble Pounder Join Date: Sep 2008 Location: philly
| Re: Shock oil
I remove the spacers and use any were from 10-40 wt depending on how I want my suspension to work. 10 will be fine, if it is reacting too fast go up.
05-02-2015, 08:59 PM | #3 |
Pebble Pounder Join Date: Oct 2008 Location: Oshawa, Ontario Canada
| Re: Shock oil
30 should not be to stiff, what piston are running in the shock?
05-02-2015, 09:32 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Shock oil
Axial 30wt is thinner than Associated 20wt, it shouldn't be too stiff especially with the kit 7mm pistons. You may have something wrong with the shocks. Which kit are we talking about? |
05-02-2015, 10:49 PM | #5 |
| Re: Shock oil
The unlimited kit
05-02-2015, 11:41 PM | #6 |
| Re: Shock oil
Those Icon shocks and machined pistons should be pretty smooth, make sure they're not too full. This can cause them to rebound way too soon in the stroke and that could cause them to feel stiff or packed.
05-03-2015, 04:39 AM | #7 |
| Re: Shock oil
When the shock is filled correctly you should be able to compress it fully with out the spring and it should rebound slowly out on its own.
Shock oil - Similar Threads | ||||
motor oil as a shock oil? | Mr.JayDeeM | General Crawlers | 10 | 09-02-2012 10:59 PM |
Shock oil and shock spring help | entropy | General Crawlers | 10 | 01-29-2011 08:40 AM |
what shock oil | TrademarkJeff | General Crawlers | 3 | 09-21-2010 03:13 AM |
best shock oil and gear oil | j4k3 | Axial SCX-10 | 2 | 07-26-2010 12:48 PM |
What Shock Oil To Use? | bcooper | Newbie General | 12 | 11-25-2006 08:36 AM |
