05-06-2015, 10:00 AM | #1 |
Newbie Join Date: Apr 2015 Location: Upstate NY
| gearing options (dual slipper spur)
I just got the deadbolt and it has the dual slipper hex spur in 32 pitch. I have searched and searched and dont seem to find any other options. I know I can drop the pinion a couple teeth but I would like a bigger spur if possible. Also does any one know what the biggers spur you can run with the cover on is. Im going to compare the dual disk associated spurs at the end of the week and see if there compatible I will post my results as soon as I can put them side by side.
05-06-2015, 11:34 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
| Re: gearing options (dual slipper spur) |
05-06-2015, 12:45 PM | #3 |
I joined the Band! Join Date: Dec 2014 Location: Earth
A 60 tooth is about as big as it gets and still use the gear cover and there may be a little gear cover/spur gear rubbing from it, at 64 teeth you may be hitting the driveshaft yoke/coupler.
05-06-2015, 03:26 PM | #4 |
Thanks. I did find the 64 on ebay but thought the same thing probably way to big. Ive seen some pretty smooth slow crawling from these trucks on you tube and asumed it was from lower gearing but now im wondering if they were just running 55 turn motors?
05-06-2015, 03:34 PM | #5 |
Newbie Join Date: Feb 2015 Location: Chicago
55 turn motor or a smooth throttle finger
05-06-2015, 04:11 PM | #6 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
| Re: gearing options (dual slipper spur) Or good radio setup. I've got servo speed on the throttle side around 5% (slows down power on) and Throttle exponential at +40% (less reaction for first half of trigger pull). I'm going for more of a scale thing, so I like the driving dynamics scaled as well. My steering servo is running around 5% as well! |
05-07-2015, 11:40 AM | #7 | |
| Re: gearing options (dual slipper spur) Quote:
05-07-2015, 11:23 PM | #8 |
Rock Crawler Join Date: Mar 2014 Location: Union City, CA
I pulled a 9 tooth pinion out of my parts bin and I like it a lot.
gearing options (dual slipper spur) - Similar Threads | ||||
Slipper/Spur Help | WesTX | Axial Wraith | 3 | 11-20-2014 07:09 PM |
Non slipper spur retainer | Solid94 | Axial SCX-10 | 2 | 08-25-2014 02:15 PM |
