11-18-2014, 07:53 AM | #1 |
Rock Crawler Join Date: Jul 2008 Location: Pearland, TX
| Slipper/Spur Help
OK, in my wraithzilla build I am running the RC4WD transmission and a Tekin Redline 13.5 Brushless system. I wanted a nice slipper unit and the RC4WD slipper that came on it had a plastic spur gear. So I bought a Robinson Racing Slipper setup but it is a 48P 80 tooth spur that has a small diameter and therefore the pinion is still 1-2 mm away from the spur when I have the motor moved as close as possible to the spur. So what options do I have? I really like the robinson slipper design, any metal spur gears that will work with it? Preferably 32P in the 54-58 tooth range. Thanks Wes |
11-18-2014, 10:35 AM | #2 |
| Re: Slipper/Spur Help
Cancel this, ordered the slash slipper unit from Robinson Racing, gets me back to 32P as well. Wes |
11-20-2014, 07:03 PM | #3 |
Newbie Join Date: Jun 2014 Location: Australia
Let us know how this works out. Im running basically the same set up and have noticed some wear on the RC4WD spur after just one run. (also broke an axial front universal) |
11-20-2014, 07:09 PM | #4 |
Will do, hopefully I'm driving it this weekend! Wes |
Slipper/Spur Help - Similar Threads | ||||
Non slipper spur retainer | Solid94 | Axial SCX-10 | 2 | 08-25-2014 02:15 PM |
Slipper clutch/ spur gear | meanbgreen | Newbie General | 6 | 09-02-2011 08:20 AM |
Spur size with MIP and slipper | DMC | Axial AX-10 Scorpion | 4 | 12-17-2008 02:47 AM |
