05-26-2015, 05:07 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| 32P pinion/spur choice
Hello, I am going to be running 36/14 and 43/13 gear set, HH 35T TMpro motor. I have a 32p 60/9t pinion & spur and 54/14 what combo would be best for crawling while keeping cool temps? Thanks |
05-26-2015, 05:16 PM | #2 |
| Re: 32P pinion/spur choice
Divide 60 by 9 and 54 by 14 and your question is answered.
05-26-2015, 08:15 PM | #3 |
| Re: 32P pinion/spur choice |
05-26-2015, 08:18 PM | #4 |
So some of us are not as smart as you, big man
05-26-2015, 08:20 PM | #5 |
the 60/9 combo would be best unless you are superstitious or overly religious as it is 6.66:1 lol the 54/14 combo is 3.85:1 which is horrible for crawling and motor temps.... |
05-26-2015, 08:29 PM | #6 |
05-27-2015, 04:12 AM | #7 |
I joined the Band! Join Date: Dec 2014 Location: Earth
05-27-2015, 06:22 AM | #8 |
Why is it 60/9 or 54/14? Go for 54/9 or, even better, spend the $3 and get a 10 or 11T pinion.
05-28-2015, 07:08 PM | #9 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
You must be running the stock driveshafts because 54t is the biggest I can get on mine with mips.
05-28-2015, 07:24 PM | #10 |
Junfac's, not a issue for me
05-31-2015, 12:32 PM | #11 |
So I lied! After putting a slipper eliminator on the spur is now much closer to the motor plate. I have a 56t on now. Could probably go bigger. I did have to space the motor back a couple mm's so that the pinion screw didn't contact the spur. |
06-04-2015, 12:24 PM | #12 |
06-04-2015, 06:26 PM | #13 |
Running 54/11 Im really liking this combo, good for crawling and motor and esc are cool to the touch. I do have a 10t but yet to try it. |
06-04-2015, 07:23 PM | #14 |
I think I ended up at 56/9 or 56/10. Can't remember for sure.
06-04-2015, 07:24 PM | #15 |
Was running at 54/14!!!! No wonder I couldn't crawl! Not sure why axial has you starting at 20/87 or higher as a guide for a trail truck.
06-04-2015, 08:26 PM | #16 |
I posted a couple of gear reference charts in the Wraith section, they cover 32 pitch pinions from 6-20 and spurs from 51-66, 48 pitch pinions from 10-35 and spurs from 73-96. Gearing chart |
06-04-2015, 09:11 PM | #17 |
Found this chart
06-04-2015, 10:01 PM | #18 |
Quarry Creeper Join Date: Feb 2008 Location: Albany
Ask a question and receive an answer. Awsome! |
06-04-2015, 10:09 PM | #19 |
06-09-2015, 07:12 PM | #20 | |
Newbie Join Date: Mar 2015 Location: Jonesboro
| Re: 32P pinion/spur choice Quote:
Where did u get the eliminator? Sent from my iPad using Tapatalk | |
32P pinion/spur choice - Similar Threads | ||||
32p spur/pinion conversion | shakemandril | Vaterra Twin Hammers | 6 | 12-25-2013 01:08 AM |
32p spur/pinion questions | tbilz | Formula Offroad | 16 | 05-30-2011 07:13 AM |
0.8 metric pitch spur w/pt 32p pinion | Drexcl | General Crawlers | 1 | 01-11-2011 10:43 PM |
Anyone run 32P Pinion/Spur Gears? | MDcrawler72 | Axial SCX-10 | 18 | 05-15-2010 09:38 PM |
