05-31-2015, 03:59 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| HR lockers
Hello, Will the Hot Racing Axial SCX10 AX10 Wraith Yeti Unibody SHD Differential Lockers work with curries? are am I better off getting vanquish's. Thanks |
05-31-2015, 04:14 PM | #2 |
Pebble Pounder Join Date: Nov 2012 Location: imperial
| Re: HR lockers
I went with vanquish and love it. There's zero play because there's a set screw that clamps down on each drive shaft. Check out my build at "what does a $2,200 scx10 look like"
05-31-2015, 04:26 PM | #3 |
| Re: HR lockers
Is anyone using the HR's in their curries? I would like to cut back on the cost alittle. My drivetrain, and all gears are HD, maybe the axial lockers with plastic housing is a good thing? Thanks |
05-31-2015, 04:39 PM | #4 |
| Re: HR lockers
totally understand on the price. if though, you decide to go with the Vanquish you will love it. so if that helps justify the purchase, I don't know, but if you do but them you'll have zero slop. the below pic... those 2 set screws go in the middle of the floating locker and tighten down right onto the shafts. zero play, really cool design. |
05-31-2015, 04:42 PM | #5 |
| Re: HR lockers |
06-02-2015, 07:03 PM | #6 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
| Re: HR lockers
To answer your question they do work with no problem.
06-02-2015, 08:14 PM | #7 |
| Re: HR lockers |
06-02-2015, 10:13 PM | #8 |
Quarry Creeper Join Date: Nov 2008 Location: Vacaville
| Re: HR lockers
I have the HR spools in my curries and I didn't use gasket on the ring gear but you should shim pinion gears.
06-03-2015, 10:24 AM | #9 | |
| Re: HR lockers Quote:
LOckedUpRC FI spool! Locked up RC - FI Spool | |
06-06-2015, 04:41 PM | #10 | |
| Re: HR lockers Quote: So these will fit in both scx10 stock axles, and currie with out any issues? Thanks, actually RPP doesn't sell them, I like to do my business with them, Gonna order up 3 sets of the HR's 2 for stock axles, 1 set for curries. I wish I could afford 3 sets of Vanquish lockers... Last edited by desertdude; 06-06-2015 at 04:47 PM. | |
06-09-2015, 07:36 PM | #11 |
| Re: HR lockers
Do I use the gasket with the stock axle's?
06-09-2015, 08:18 PM | #12 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: HR lockers
all depends on the gear mesh of ring & pinion, on most of the HR lockers I've had, no gasket needed. However the last HR locker I bought I had to use the gasket to get my Axial HD OD gears to mesh/turn freely. After opening up my AR60 axles and finding one of my HR lockers cracked I won't waste my money on anymore lockers from HR.... Locked-up lockers from now on out..
06-09-2015, 09:29 PM | #13 | |
06-10-2015, 07:23 AM | #14 |
| Re: HR lockers
So no gasket using stock ratio HD gears, stock axles? Im putting them in after work today.
06-10-2015, 07:31 AM | #15 |
Newbie Join Date: May 2015
| Re: HR lockers
I installed mine with no gasket and stock bevels and my scx axles spin freely. I'm using the orange clamping hr lockers
06-10-2015, 02:05 PM | #16 | |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
I use the HR's and I just can't imagine them cracking! I could see them wearing out an axle though. | |
06-10-2015, 03:05 PM | #17 |
| Re: HR lockers |
06-10-2015, 05:31 PM | #18 |
| Re: HR lockers |
06-10-2015, 06:09 PM | #19 |
| Re: HR lockers |
06-10-2015, 06:10 PM | #20 |
| Re: HR lockers
Is that with stock axles inserted?
HR lockers - Similar Threads | ||||
Which lockers? | h8z2luze | Losi Mini-Rock Crawler | 5 | 09-29-2009 01:08 AM |
Replace Hr Lockers With Berg Lockers | Yawzer | General Crawlers | 5 | 12-29-2008 10:51 PM |
