06-05-2015, 06:53 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: SB
| Side 2 side axle play question
Hello, I was noticing their is some side to side axle play when I hold the frame and move/wiggle the axle. Is this normal, I really never noticed it before. Thanks |
06-05-2015, 07:00 PM | #2 |
I joined the Band! Join Date: Dec 2014 Location: Earth
| Re: Side 2 side axle play question
You'll have some movement, the pivot balls in the rod ends are a little sloppy plus there's some minor flex in the suspension. If it seems excessive check the links to make sure they're tight and check the rod ends/pivot balls for wear or damage.
06-05-2015, 07:11 PM | #3 |
| Re: Side 2 side axle play question Thanks, its not to excessive so I will let it be, but I will check the pivot balls and make sure everything is tight.
06-05-2015, 07:12 PM | #4 |
...normal Ever increasing wear at the link's eye ends (consumable) will increase the axle's lateral movement (play - slop). Higher quality - beefier link ends could tighten up that play some. Replacing the plastic pivot balls with metal balls offers tighter tolerances. But because the link ends/balls are a consumable item... it may be pertinent to exchange for new on occasion. |
06-05-2015, 07:44 PM | #5 |
Makes sense thanks buddy, Putting in HD gear tomorrow, I will just swap out all the pivot balls
06-05-2015, 09:12 PM | #6 |
wow yes replaced all the ball ends, much better |
Side 2 side axle play question - Similar Threads | ||||
Baja Claw and Flat Iron 1.9 side by side? | JDeezie82 | Tires and Wheels | 3 | 02-28-2011 08:19 AM |
RC4WD Lox & Crawler Tire Pictures Side By Side | stomper4x4.com | Losi Micro-Rock Crawler | 9 | 07-27-2010 07:34 PM |
Traxxas Slash & Losi Desert Truck Side by Side | RPP Hobby | RPP Hobby | 26 | 06-24-2008 03:32 AM |
