06-06-2015, 03:00 PM | #1 |
Newbie Join Date: Jun 2011 Location: bakersfield
| scx10 esc problems ok today i set my scx10 up. im using a flysky reciever with a turnigy gtx3b transmitter. ive got the stock 27t brushed motor hooked up to a hobbywing ezrun 35amp esc running on a 6 cell nimh pack. problem is ill running forward or reverse and it will run at full throttle which isnt fast at all and then it will just cut out. esc with blink red. ill hit the transmitter in reverse real quick then the green light will come on and i can go forward again for lil bit and then it will die again. and if i hook a 7 cell nimh it dies and i have to turn the esc off and turn it back on to get it to move. Did i do something wrong or is the esc need something or is the esc just junk??? |
06-06-2015, 03:04 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
Try charging the battery up again then rebind the rx and the tx then recalibrate the ecs. If you don't have the instructions there should be a utube video to help with each step.
06-06-2015, 03:32 PM | #3 |
| Re: scx10 esc problems
Sounds to me like the Lipo cutoff is on, and it is running in reverse...
06-06-2015, 03:43 PM | #4 |
Lipo cutoff is on...either disable it or run a lipo battery
06-06-2015, 05:24 PM | #5 |
| Re: scx10 esc problems how do i turn of the lipo cut off? i dont have a program card. |
06-06-2015, 05:43 PM | #6 |
If you don't have the manual...download it and see what it says on how to disable the lipo cutoff
06-06-2015, 11:17 PM | #7 |
| Re: scx10 esc problems i did look up the manual on google and i turned off the LVC on the esc but it still cutting out. Im thinking this esc wont work on a brushed motor. Says nothing about running a brushed motor on its speicifications. |
06-06-2015, 11:25 PM | #8 |
I joined the Band! Join Date: Dec 2014 Location: Earth
If it doesn't say brushed motors or have wiring instructions on using a brushed motor, then it's not brushed motor compatible. The majority of brushless ESC's are brushless motor only.
06-06-2015, 11:48 PM | #9 |
yup, it says right on the website specs: sensorless brushless motor capable only...why would you want to run a brushed motor on a brushless esc is what I dont get, I see people doing it with the castle esc's and such but wonder why... just get a brushed esc and be done with it... 1.1 Output: Continuous current 35A, burst current 190A. 1.2 Input: 4-9 cells NiMH/NiCd or 2-3 cells LiPo. 1.3 BEC Output: 6V/1.5A. 1.4 Resistance: 0.0015 Ohm. 1.5 Motor Supported: Sensorless Brushless Motor 1.6 Suitable Brushless Motor: With 4-6 cells NiMH/NiCd or 2 cells Lipo: On-Road≥9T, Off-Road≥12T; With 6-9 cells NiMH/NiCd or 3 cells Lipo: On-Road≥12T, Off-Road≥18T; 1.7 Suitable Car: 1/12, 1/10 on-road or off-road cars / trucks for normal race or sportful race. 1.8 Size: 31.5mm(L) * 27.5mm(W) * 24mm(H). 1.9 Weight: 30g(Without wires) |
scx10 esc problems - Similar Threads | ||||
servo/esc problems on scx10 | Finnigan182 | Newbie General | 3 | 05-11-2011 01:48 PM |
esc problems | hotbodies racer | Electronics | 4 | 02-09-2010 07:55 AM |
Problems with ESC??? | Rockmuncher | Electronics | 8 | 01-18-2007 10:14 AM |
2 esc problems | EMUTT | Tamiya Clod Buster | 6 | 10-09-2006 06:17 AM |
ESC problems | Inkmaxx | Tamiya Txt-1 and Juggernaut | 2 | 10-18-2004 05:44 PM |
