06-08-2015, 02:54 PM | #1 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| DowntownScience's ever evolving SCX10
My SCX10 has changed a bit since my last thread. Wasn't sure how to change the original thread name so I'm starting a new one with a title that is sure to last the truck's lifetime! Link to first thread: RTR Trail Honcho turned 1980 Chevy K10 Pre-Runner (my first scaler) |
06-08-2015, 02:55 PM | #2 |
| Re: DowntownScience's ever evolving SCX10
As the truck currently sits now... Last edited by DowntownScience; 06-26-2015 at 05:13 PM. |
06-08-2015, 03:14 PM | #3 |
| Re: DowntownScience's ever evolving SCX10 Modifications: Electronics: Futaba 4PLS Transmitter Tekin FX-R combo with 35T motor Castle BEC (6v direct to servo) Savox SA-1230SG Servo 2S LiPo 5800 mAh batteries Transmission: Stock housing RRP Steel idler/differential gears FastEddy bearing set GPM slipper eliminator Geared 56/9 (32P) MIP Driveshafts w/ Traxxas Pin Screw (TRA5145) Axles: Stock housing Axial Heavy Duty 36T/14T gears (over drive front) Axial Heavy Duty 38T/13T gears (stock rear) Hot Racing Unibody Differential Lock (F/R) Axial Aluminum C-Hubs Axial Aluminum Knuckles Blue Monkey R/C Knuckle Weights Axial Aluminum Rear Axle Lockout Pro-Line Racing 12mm hex for Slash 2WD Front (8mm F/R) Suspension: STRC 4-Link Truss (F/R) Aluminum 4-Link (F/R) Team Associated V2 Rear Shocks (F/R)
Wheels/Tires 6 spoke aluminum 1.9 Chinese specials from eBay Crawler Creations 2-stage foams for 4.7" tires PitBull Rockbeast 1.9 Other: Electronics/Battery Plate (eBay) R/C Rock Armor G6 Front Winch Bumper R/C Rock Armor SCX10 Rear Bumper with Led Hole R/C Rock Armor Recovery Hitch Last edited by DowntownScience; 06-11-2015 at 04:21 PM. |
06-08-2015, 04:30 PM | #4 |
| Re: DowntownScience's ever evolving SCX10 Body: I was ready for a Jeep and a guy I know is part of the Nor Cal Jeep Cherokee club. I liked the look of his truck and thought I'd go for it. Will have to get a picture of his truck as it did serve as motivation for this project. Here are a few other Cherokees that served as inspiration for paint, fenders, etc. I knew I wanted my paint to look like this when I saw it online. I started by spraying the body Tamiya Translucent Green. It's really hard to gauge what this paint is doing and I definitely used too much! After the Translucent Green was Tamiya Fluorescent Green backed with Tamiya Silver and the last coat Tamiya Black. The windows were also tinted using Tamiya Smoke. Rears are darker than the windshield and fronts. My green is a bit darker than I had envisioned, but it still looks awesome in the sun! Last edited by DowntownScience; 06-08-2015 at 04:38 PM. |
06-08-2015, 04:54 PM | #5 |
| Re: DowntownScience's ever evolving SCX10 Wheels and Tires: A list of the tires that I've purchased (from newest to oldest) and my thoughts about them...
Front (with battery mounted): Rear: Last edited by DowntownScience; 06-08-2015 at 10:43 PM. Reason: L |
06-10-2015, 08:47 PM | #6 |
Moderator Join Date: Jan 2004 Location: chicago
neat looking truck. ;) i used the flipfloppy tamiya green/purple on a dingo body and it totally looked like i didnt have enough coats before i backed it. |
06-11-2015, 04:28 PM | #7 |
| Re: DowntownScience's ever evolving SCX10 Shocks: I use Team Associated V2 shocks. They're nothing special, not threaded. They are very inexpensive, stroke nice, are easy to rebuild, and have many spring choices. For around $25- you can get a set of F/R from a parted out SC10 RS or other SC10 RTR on eBay. So for 50- you've got 2 sets of shocks to play with. One around 90mm and the other around 100mm. I use the "rear" shock assembly on all four corners, but use the "front" springs. This gives me a nice amount of play to get my droop to 40% using pre-load spacers. One of the greatest things about these shocks is that the lower spring retainers won't fall off whether the spring has tension on it or not. Team Associated designed the slot on the lower shock collar to be smaller than the shock piston so that you have to use some force to get the piston into the collar and then it seats on the lower eyelet. The Team Associated front springs weights are higher than the rears in their respective colors. I like a stiffer spring because I don't like the body bouncing around or rolling over too much and I'm now using a 40 wt oil (instead of 30) to slow things down a bit. Never liked how when the truck would come off of an obstacle it looked like a bobble-head doll! Last edited by DowntownScience; 06-11-2015 at 04:37 PM. |
06-11-2015, 05:14 PM | #8 | |
| Re: DowntownScience's ever evolving SCX10 Quote:
What's cool about it is the dimension/shading effect it gives in the cracks and crevices that you may have put a little too much paint in! I really like that color you're talking about you have a pic? Remember when they started putting out cars like that 15 or so years ago. | |
06-13-2015, 10:13 PM | #9 |
Rock Stacker Join Date: Dec 2013 Location: The Mitten
| Re: DowntownScience's ever evolving SCX10 |
06-16-2015, 01:30 PM | #10 |
Rock Crawler Join Date: Apr 2009 Location: bend
I always set up my crawlers 60/40. I have a can am maverick SXS and it is also set up 60/40. I had Don at Thuren Fabrication set the mavericks shocks.
06-26-2015, 05:18 PM | #11 | |
DowntownScience's ever evolving SCX10 - Similar Threads | ||||
My Evolving SCX10 | n_d_fox | Axial SCX-10 | 24 | 01-21-2016 03:53 AM |
My ever-evolving SCX10 | ProjectSCX10 | Axial SCX-10 | 71 | 10-17-2013 02:57 PM |
Evolving SCX10 | CAPCbass | Axial SCX-10 | 9 | 08-16-2013 03:39 AM |
The Evolving SCX | jdacus | Axial SCX-10 | 4 | 03-26-2013 09:35 PM |
My ever evolving xr | adamargue | Axial XR10 | 29 | 10-27-2011 12:00 PM |
