06-29-2015, 07:14 PM | #1 |
"GOD SPEED" Join Date: Oct 2014 Location: Wouldn't you like to know
| Carbon fiber scx10
Here is my custom built scx10 Carbon fiber chassis, designed by me Custom carbon fiber links w/ revo ends made by me Custom carbon fiber link and servo mount by me Carbon fiber braces Carbon fiber electronics trays smw scx10 skid holmes 40t brushed motor holmes brxl hitech 7954 servo w/ bec xr10 width front and rear axles with rcbros burly tubes vp 2.2 wheels with stretched 1.9 pitbull rockbeast geo tracker body deadbolt driveshafts vp trans case with hardened gears slipper eliminator truck has extremely low center of gravity, 11 1/8" wheelbase and 10" wide Sent from my SAMSUNG-SM-G870A using Tapatalk |
06-29-2015, 09:02 PM | #2 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| Re: Carbon fiber scx10
where can i get that body
06-29-2015, 09:07 PM | #3 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
That's a proline descended body. It's discontinued :-(
06-30-2015, 07:02 PM | #4 |
Being that the truck is so light it slides much easier over the rocks and doesn't have as much force on the chassis and the carbon slides better than anything I have ran so far. Sent from my SAMSUNG-SM-G870A using Tapatalk |
06-30-2015, 07:24 PM | #5 |
Rock Crawler Join Date: Nov 2011 Location: Asheville
What's your final weight? Looks good by the way. I think that the links may be a weak point. Carbon fiber uppers didn't last long in my comp rig. Sent from my DROID RAZR HD using Tapatalk |
06-30-2015, 07:28 PM | #6 |
Haven't got my final weight still waiting on new holmes stubby motor and crushed esc, the links have a sideways breaking point of 80lbs, I don't think they will break easy. I am hoping to come in under 6lbs. Sent from my SAMSUNG-SM-G870A using Tapatalk |
06-30-2015, 07:30 PM | #7 |
where can i get that body I actually have 2 new ones in the packages still, going to paint a new one soon. since this body is almost destroyed, I ran it on my old 1.9. I built this chassis around this body. Sent from my SAMSUNG-SM-G870A using Tapatalk |
07-01-2015, 08:12 PM | #8 |
Action pic Sent from my SAMSUNG-SM-G870A using Tapatalk |
07-01-2015, 09:18 PM | #9 |
Rock Stacker Join Date: Mar 2014 Location: Albuquerque
Where did you get the carbon fiber at? I about to do this too! Trane |
07-01-2015, 09:38 PM | #10 |
ebay Sent from my SAMSUNG-SM-G870A using Tapatalk |
07-01-2015, 10:49 PM | #11 |
What thickness is it? Trane |
07-02-2015, 07:21 AM | #12 |
The stuff I used was 2.5, I am currently making another one from 3.125 for my 2.2 truck
07-02-2015, 09:16 AM | #13 |
damn that a cool body
07-02-2015, 01:25 PM | #14 |
Saw this rig do some work Comping last weekend it had a very good maiden performance and those CF links look really dope. Sweet chassis Adam. |
07-03-2015, 10:25 AM | #15 |
weighed truck today, still need different motor and esc and gonna go back to plastic trans housing, but as it sits now with battery it is 4lbs 9oz. hopefully around 4lbs when all done.
07-03-2015, 10:51 AM | #16 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
More info on how you made your links and what they weight - if you don't mind. And FYI - your collars for the rcbro tubes are on backwards. Smaller (less OD) should face in. Sent from my SM-G900V using Tapatalk |
07-03-2015, 10:57 AM | #17 |
| Re: Carbon fiber scx10 links are made from carbon fiber tubing, not much different weight than stock plastic links but slide way better and are much stronger. Colors are switched, those pics were of mock up.
07-03-2015, 10:58 AM | #18 |
What size and do you just tap the ends? Sent from my SM-G900V using Tapatalk |
07-03-2015, 11:19 AM | #19 |
| Re: Carbon fiber scx10 |
07-06-2015, 06:34 PM | #20 |
Just weighed the truck today after changing trans case and installing hot racing hardened aluminum gears. Truck is at 4lbs 6.6oz with battery, once new holmes 2200 stubby and crushed esc is installed I'll weigh again. so far links and chassis are holding up great on rocks. Sent from my SAMSUNG-SM-G870A using Tapatalk |
Carbon fiber scx10 - Similar Threads | ||||
Carbon Fiber Motor Plate for the AX/SCX10 Transmission | Tomy | Axles, Trannys, T-case | 12 | 06-17-2013 03:36 PM |
carbon fiber | phllint | General Crawlers | 0 | 08-28-2011 07:27 PM |
got carbon fiber? | STANG KILLA SS | Chit Chat | 14 | 09-24-2009 07:11 AM |
Carbon Fiber and more | motorman1600 | Losi Mini-Rock Crawler | 1 | 05-26-2009 10:49 PM |
