07-14-2015, 10:31 AM | #1 |
| which hole are your shocks mounted to in the shock towers?
post a picture if you got it |
07-14-2015, 11:50 PM | #2 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
| Re: which hole are your shocks mounted to in the shock towers?
I mount mine in the round hole |
07-14-2015, 11:58 PM | #3 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
whaaaat,Is this a trick question,there's only 3 holes...Doesn't it depend on WB......
07-15-2015, 12:16 AM | #4 |
Probably not a trick question, Stang is the eternal newb.
07-15-2015, 01:16 AM | #5 |
| Re: which hole are your shocks mounted to in the shock towers? |
07-15-2015, 01:58 AM | #6 |
Rock Stacker Join Date: Jan 2009 Location: Rio Rancho NM
Middle hole, because I didn't put any thought into it. Just because the last guy did it, I gotta do it too.lol Last edited by 505tj; 07-15-2015 at 02:22 AM. |
07-15-2015, 07:45 AM | #7 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
| Re: which hole are your shocks mounted to in the shock towers? Back one.... Cause business up front, party in back. |
07-15-2015, 08:17 AM | #8 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I try to position my shock as much vertical as possible. The placement really depends on wheelbase and ride height. If my wheelbase doesn't allow for a nice low stance with vertical mounting I lay the shock back slightly. I like my rigs with a nice low stance and I think vertical mounted shocks work and look scale
07-15-2015, 08:37 AM | #9 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
| Re: which hole are your shocks mounted to in the shock towers? Front and rear Sent from my iPhone using Tapatalk |
07-15-2015, 01:22 PM | #10 |
| Re: which hole are your shocks mounted to in the shock towers? no not a trick question. were constantly trying to evolve our products. was looking to expand our shock mount options by seeing if most are mounting more towards the inner holes or outer holes front and rear. |
07-15-2015, 01:32 PM | #11 |
Rock Crawler Join Date: Jan 2010 Location: rockford
What if your running a cantalever ? Just saying..
07-15-2015, 01:41 PM | #12 |
"Alpha angle"
07-15-2015, 03:04 PM | #13 |
| Re: which hole are your shocks mounted to in the shock towers? OH OK I see,Just thought it kind of funny question to ask.Well if that the case my SCX10 are in the middle.... |
07-15-2015, 05:14 PM | #14 |
Quarry Creeper Join Date: May 2014 Location: Burlington, ON Canada
I was the first to respond to this yesterday and made a post including a picture. Seems to have disappeared.
07-15-2015, 05:18 PM | #15 |
07-15-2015, 05:44 PM | #16 | |
| Re: which hole are your shocks mounted to in the shock towers? Quote:
I prefer the hole that offers the truest vertical alignment. So I use the forward most hole on the stock shock tower(s). I'd probably move it another 2 mm forward... if the stock shock tower had another hole. I'd actually like to move it forward... and upwards a few mm to lower the chassis a little as well. So a bracket (plate) that offers both adjustment, would net my interests. I could scratch build those plates... But I'd likely not be very accurate in my process | |
07-15-2015, 08:46 PM | #17 |
normally rear most hole in the front and whatever makes my rear shock 90* EDIT: I'm assuming this is for the TSS chassis? Last edited by fr8cture; 07-15-2015 at 08:52 PM. |
07-16-2015, 12:34 AM | #18 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
Seriously what's in the Taco's Vender, your getting a little feisty
07-16-2015, 01:21 AM | #19 |
07-18-2015, 09:51 AM | #20 |
Newbie Join Date: Jan 2012 Location: Ruston
I have the holes marked on the chassis that I used but it really depend on the hight of shock and wheel base Sent from my iPhone using Tapatalk |
which hole are your shocks mounted to in the shock towers? - Similar Threads | ||||
Trailing arm mounted shocks vs axle mounted shocks on a wraith? | mudweaver | Axial Wraith | 39 | 01-16-2015 08:37 AM |
shock towers | travis43822 | Axial SCX-10 | 2 | 01-17-2011 04:14 PM |
****Shock Towers**** | 73formulabird | Axial SCX-10 | 2 | 05-02-2010 01:16 PM |
