Thread: SCX-10 Class 2 Build
Old 06-28-2015, 02:45 AM   #1
Default SCX-10 Class 2 Build
Not Very Good At These Build Treads But Will Try
Started Life as a Honcho
Broke most the plastic stuff first day out, So started to rebuild, Ordered up a Integy Alloy Kit, And a metal rear cage off ebay
Went with a RC4wd Bumper and winch.
Test fitting the F250
Quick Mock up, 2.2 Alloy Integy Wheels, Pro Line Flat Irons
Got the Rc4wd metal side bars, GCM front motor plate and Tcase, HR 4 Link 12.3WB Integy 100mm piggyback shocks,GSM CMS,Rc4wd 35t motor, Integy metal spur gear, RP 19tooth Pinon, Integy heat sink, Integy Driveshafts, Knockles, draglink and Axle shafts, Rc4wd 2 Speed trans.
Had to make a custom shifter plate.
Videos Of The Shifter
https://youtu.be/YE97prIksd8
https://youtu.be/qD1S_XL4cpk
Ordered up a Rc4wd 3 Link panhard kit, had to modify it
Got the new controller in 9 Channel
And now im starting on the Floorboard and dash.
06/29/15
Could not find metal body post long enough so made some from old 3000GT intake bolts
Started working on the bed panels
07/08/15
Added a rear tire mount to the cage, Getting it sand blasted
Primered
3rd coat of paint
Got all the pan and tilt setup in today
Ready for camera
Pan And Tilt in action
https://youtu.be/WsFCHnWD9N4
Body painted and reinstalled
07/16/205
Axles showed up today
07/19/2015
Lot of stuff to do today
Got the new steering servo in today.
Got some help from a friend
Most of the wiring in the truck
After a few hours and hours of heat shrink deans connectors.
Took it out had a little fun made it about 30 minutes till it broke. lol the one weak link....
08/04/2015
Broke about 5 more sets of driveshafts so i broke down and bought mip's
also moved the motor back to the center put 19mm spacers and the vp High steer knuckles
Moved the rear links to the front and made custom 1" longer ones for the rear I drives great know
I was started to get a little depressed when my stock honcho could out drive it but it does weigh in at almost 14lbs
but know its pretty close and a heck of alot funner to drive.
The front yard playground we are setting up.
Pureevil is offline   Reply With Quote
Old 06-30-2015, 01:22 PM   #2
Default Re: SCX-10 Class 2 Build
looks really good. did you mount that cage on the back of the frame?
Sent from my SAMSUNG-SM-N910A using Tapatalk
mottillod is offline   Reply With Quote
Old 07-08-2015, 02:42 PM   #3
Yep, mounted to the rear bumper holes
Old 07-08-2015, 05:55 PM   #4
Do you have the part numbers for the trans mount/trans/transfer case/ drive shafts? That is a SWEET setup! Nice work!
Zac_F71 is offline   Reply With Quote
Old 07-16-2015, 08:16 PM   #5
I posted it 3 times, i guess i will pm them to you
SCX-10 Class 2 Build - Similar Threads
Famous112's Gelande II Build! / Class 1 ( 1.9 ) Build Famous112 1.9 Scale Rigs 3 04-07-2014 09:18 PM
Tamiya FJ40 SCX-10 for UTRCRC Street Class Just Zach 1.9 Scale Rigs 63 10-18-2012 01:54 PM
