07-25-2015, 07:10 PM | #1 |
Rock Stacker Join Date: Jul 2014 Location: Hollis
| Need advice on some wheels
Hi all, Looking into some beadlocks for the Deadbolt. I have looked at some from RC4wd and the Axial eight hole beadlocks. Can anyone give me any insight to the performance of these choices? The RC4wd wheels are the Pro 10 steel Wheels form RPP. Thanks Scott |
07-25-2015, 07:26 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
My sons dingo has 1.9 8 holes and they are fine. Held up to 4 yr old for 10 months
07-25-2015, 07:46 PM | #3 |
Rock Crawler Join Date: Mar 2006 Location: Dogpatch
| Re: Need advice on some wheels |
07-25-2015, 07:53 PM | #4 |
I joined the Band! Join Date: Dec 2014 Location: Earth
Look into the SSD D-hole 1.9", I've got RC4WD wheels on a Dingo and like them just fine. What I didn't like was the hex nuts on the face of the wheels, socket screws from the back and the pin drive center hub. SSD wheels use the 12mm hex hub and socket screws from the front threaded into the center hub (no hex nuts). If these things don't bother you then the RC4WD wheels will be fine as they're well made steel wheels. The SSD wheels are available at RPP for just $10 more than the RC4WD. SSD Wheels - D HOLE SILVER SSD 1.9" STEEL D HOLE WHEELS (SILVER) (2) - at RPP Hobbies SSD Wheels - D HOLE BLACK SSD 1.9" STEEL D HOLE WHEELS (BLACK) (2) - at RPP Hobbies |
07-25-2015, 11:25 PM | #5 |
I like my Axial 1.9 BL's so much... I want a 2.2 8-hole set for my 1/6 scale build. I've run them for over two years on my T Honcho and have installed more then a few different tires on them. Screws hold fine as long as they're not over turned. The bead locks seal fine with most tires I've used ( I don't vent ) The hex hubs have never rounded out. Only thing I'd change... is the bead lock rings. Would prefer steel over aluminum. Tho' the aluminum rings have held up just fine. |
07-26-2015, 08:02 AM | #6 |
RCC Addict Join Date: Aug 2012 Location: The Garage!!!
Axial 8's have many ring options stock(any color),lurc,MThead, gearhead,etc plus scale hardware! The only bad imo is the offset where you may be running VP hi steer knuckles there could be clearance issues. All tires mount with ease!!! Rc4wd wheels as mentioned have offset options,non beadlock look & steelies look cool rusted up but beware some tires are pita or impossible to mount even with the vp omf or proline internal rings. I would also check out Duuuuude on here & look at his custom delrin wheels with any ring bolt pattern so options are unlimited! |
07-26-2015, 10:01 AM | #7 |
Rock Crawler Join Date: Nov 2004 Location: Lost in Florida
Ssd!!! |
07-26-2015, 07:36 PM | #8 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
I think the SSD's would be a good choice, I like the added weight of the steel wheels.
07-27-2015, 12:56 AM | #9 |
RCC Addict Join Date: Feb 2012 Location: UK
07-27-2015, 06:34 AM | #10 |
Thanks for all the replies. I like the Axial wheels, as well as the RC4wd steel wagon wheels. The SSD-RCs are nice, but I'm wanting inexpensive. Is there any problem with the pin mount as apposed to the 12mm hex? Does it effect the offset at all? Again, thanks! Scott |
07-27-2015, 07:05 AM | #11 |
Offset would be the same unless you choose different offset hubs. Hex is better as if the wheels comes loose you have less chance of loosing the pin. |
07-27-2015, 04:42 PM | #12 | |
| Re: Need advice on some wheels Quote:
07-27-2015, 05:08 PM | #13 |
Newbie Join Date: Jun 2015 Location: Bristol
Less chance of stripping the hub also with hexs Sent from my iPhone using Tapatalk |
07-28-2015, 09:54 PM | #14 |
Quarry Creeper Join Date: Feb 2015 Location: Amongst the UTards
Bought my RC4wd wheels from the RPP salvage yard. Be sure to buy hex hubs. Hubs are often out of stock. Sent from my Nexus 7 using Tapatalk Last edited by scaled; 07-28-2015 at 09:57 PM. |
Need advice on some wheels - Similar Threads | ||||
Need advice on wheels | DrewHammer | Axial Wraith | 9 | 07-02-2013 07:40 AM |
1.9's on 2.2 Wheels, questions and advice | AsILayDying | Tires and Wheels | 2 | 08-04-2012 06:29 PM |
Foam trimming advice for Sedonas on 1 inch wheels | cpercival | Axial XR10 | 6 | 03-10-2012 06:24 AM |
cutting stock Clod wheels ... advice please | v33 | Tires and Wheels | 5 | 08-23-2005 04:21 PM |
