08-04-2015, 11:33 AM | #1 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
| Rear Cab Mounts
I'm sticking a new Honcho shell (cab only) on my chassis. I've done my usual magnetic mounts on the front half. Now I'm trying to work out a way to mount the rear wall of the cab to the frame rails.. I've figured out several ways to attach it with screws, but I'd like it to be easily removable. The front half, with the magnets, is acting as the hinge. Any ideas? One thought I had is to glue a piece of styrene in place to reinforce the rear wall and look for ideas based in hardbody mounting methods. Sent from my iPad using Tapatalk Last edited by monkeyracing; 08-04-2015 at 12:35 PM. |
08-04-2015, 04:49 PM | #2 |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
| Re: Rear Cab Mounts
Why not use magnets all around?
08-04-2015, 09:09 PM | #3 |
| Re: Rear Cab Mounts
I find they've got a bit of lateral slide to them. In the past, with full shells, I'd peg down the back of the body at the rear bumper, so the front stays kinda lined up. I might see if there's something I can do, though. Jim |
08-04-2015, 09:54 PM | #4 |
| Re: Rear Cab Mounts
you could do something similar to this... exclude the hoop... but build a bracket to support pins at the rear cabin wall. bolt on kit for morpheus_tn... |
08-04-2015, 11:56 PM | #5 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: Rear Cab Mounts
or if you don't mind drilling holes in your roof you can make something similar to what I did to my Honcho Truggy the front has the stock body posts and holes in the body Last edited by kgb424; 02-04-2016 at 03:44 PM. |
08-05-2015, 03:21 AM | #6 | |
| Re: Rear Cab Mounts Quote:
I like that. Well hidden, simple, strong. Kgb424 - I could do that, but I'm trying to do hidden mounts. No holes. Cool idea though. It dawned on me tonight, that the frame rails are steel (duh) and I could attach a few magnets to the base of the rear wall, so they'd stick to the chassis. The channel cut into the rear wall controls side to side motion Thanks for the ideas, guys. Jim | |
08-05-2015, 06:59 AM | #7 | |
the cab's rear fire wall lower notch (channel ?) simply spans- straddles above the frame. ...it does not center the body, nor physically touch the F rails. The original rear body mount posts keep alignment and keep the notch riding above the frame rails. If it makes contact... it will become fubar. If you might think it could serve for body alignment purpose... be sure to add some reinforcement to that back wall/notch or it will crack/rip easily. Another sheet of .040 lexan cut to shape and adhered (laminated) using E6000 might offer enough strength. I still use the rear factory post mounts (cust. velcro mnt. up front) and even with the rear post keeping the body centered that notch got torn a little from stress/body shift. Last edited by TacoCrawler; 08-05-2015 at 07:10 AM. | |
08-05-2015, 07:52 AM | #8 |
| Re: Rear Cab Mounts
I also made my own sliders and the Honcho Cab sits in the sliders and does not move around and my cab has got a tear right in the notched area in the back and that was with the stock bed on so it tearing there is common, I used shoe goo and drywall mesh and strengthened in the inside of the back of the cab too keep it from tearing more Last edited by kgb424; 02-04-2016 at 03:44 PM. |
08-05-2015, 04:10 PM | #9 |
| Re: Rear Cab Mounts Well, maybe yours don't, but mine do. I reinforced the rear wall of the cab with heavy styrene and cut it to fit over the framrails. Still doesn't help with the lateral location up front, but hey, one step at a time. Here are a few shots of the rear section and showing how I do the front mounts. |
08-05-2015, 04:48 PM | #10 |
| Re: Rear Cab Mounts |
08-05-2015, 05:30 PM | #11 |
| Re: Rear Cab Mounts
Just playing poke the bear. I wanted to channel the body as low as possible over the chassis. I'm going for something fairly scale, so it's got steel 1.55s on it too. As for how it does in rollovers...it'll probably pop right off, but I only run my backyard trail anyhow. It's pretty tame. Jim |
08-13-2015, 11:58 PM | #12 |
| Re: Rear Cab Mounts
Huh. Posted this earlier. Didn't stick. I couldn't figure out a solid hidden solution to my hinge idea, so I decided to make it look as cool as possible. I took the endplates off an old Integy lightbar, drilled a few holes and now my cab is rear hinged, with magnets holding the front down. One more bit to fab in order to keep the nose properly centered, a little paint and this one's ready for dirt! |
08-14-2015, 01:08 AM | #13 |
| Re: Rear Cab Mounts
^ tho' I'd hate to have to purchase the light bar... just to obtain those. I'd probably just use a plastic servo mount... and machine a 'lil bit with muh dremel. yeah... I'm kinda thrifty or cheap !? Lol |
08-15-2015, 02:10 AM | #14 |
| Re: Rear Cab Mounts
Thanks. This was an older, really useless light bar. Got it from a friends years ago. Never actually used it myself. So dim! Jim |
Rear Cab Mounts - Similar Threads | ||||
flipped rear body mounts?? | chopan84 | Axial SCX-10 | 2 | 04-24-2011 12:05 AM |
Rear Shock Mounts? | Grumpster1980 | Tamiya XC/CC01 | 26 | 02-19-2010 11:25 PM |
Rear Shock Mounts | TruckerBrad | Tamiya XC/CC01 | 13 | 01-20-2010 11:01 PM |
