08-06-2015, 08:28 AM | #1 |
Newbie Join Date: Nov 2014 Location: Winnipeg Manitoba
| Steering mod questions
I looked for a thread for this but kept getting the run around. My question is will high clearance steering knuckles work with any c hub, plastic aluminum, vanquish ? If someone can answer or post pics or links to where I can find the answer thank you.
08-06-2015, 08:33 AM | #2 |
| Re: Steering mod questions
The Vanquish 8 degree knuckles only work with their 8 degree c hubs. Other ones on the market (Axial, Hot Racing, etc) should work with the stock c hubs or aluminum copies but not the Vanquish 8 degree ones (the geometry is different).
08-06-2015, 08:50 AM | #3 |
yes, the axial high clearance knuckles work on stock plastic chubs, strc chubs, all except vanquish like stated above...
08-06-2015, 10:32 AM | #4 |
Rock Stacker Join Date: Jul 2015 Location: Fredneck
I just upgraded my front end to the Vanquish stage 1 kit (8 degree knuckles, c-hubs and rear lockouts). I did so because I lost a screw on one of my stock axial c-hubs after running on some rocks at a park nearby. I decided to go with this kit because the plastic c-hubs and coarse thread screws will get sloppy over time and will eventually fall out. If you can afford to do so, I would highly recommend upgrading to aluminum c-hubs and knuckles at the same time. I'm very happy with the Vanquish parts. Your mileage may vary. Have fun.
Steering mod questions - Similar Threads | ||||
xr mod questions | nwcrawler | Axial SCX-10 | 2 | 12-13-2014 08:04 PM |
new steering on the new PRO/ OTA steering mod axialjeepster | AxialJeepster | Losi Mini-Rock Crawler | 4 | 10-14-2012 01:03 AM |
Xirtic + JP High Clearance Steering Mod on Mod | JeffK11 | RC4WD Bully | 1 | 02-01-2012 09:55 AM |
A few AX-10 mod questions? | crawlcincy | Axial AX-10 Scorpion | 10 | 12-12-2008 12:33 PM |
Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
