08-22-2015, 04:11 PM | #1 |
Newbie Join Date: Jul 2015 Location: Seattle
| Scx10 Warn winch help
G'day blokes. Just received my used Axial scx10 which looks awesome. Came with Rc4wd beadlocks, interco super swampers, warn winch,proline shocks ect. In regards to the winch, it didnt come with a controller. Is there anyway i can work this without having to spend $45 on the receiver and remote unit? Can i just hook up a toggle switch to a batter? Cheers |
08-22-2015, 04:27 PM | #2 |
Newbie Join Date: Jun 2015 Location: Greenville
| Re: Scx10 Warn winch help
There are wireless winch controllers on the cheap that you can get from multiple places. I bought the yeah racing winch controller for around 20 bucks. http://www.amazon.com/Yeah-Racing-Wi.../dp/B00Q2H7J1I |
08-22-2015, 05:30 PM | #3 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
What kind of radio/reciever are you using?
08-22-2015, 09:27 PM | #4 |
Rock Stacker Join Date: Jul 2014 Location: Hillsboro
Three channel radio will fix that problem
08-23-2015, 06:29 AM | #5 |
RCC Addict Join Date: Nov 2008 Location: Bunnell, Fl.
As mentioned above.....what transmitter are you using? If you have one that is 3-channel and have either a 2-position switch or 3-position switch for your 3rd channel, HeyOK makes a simple winch controller that will work great for you. Winch Controller for three position channel |
08-23-2015, 12:47 PM | #6 |
Thanks guys, have the stock transmitter that comes with the honcho. Ax 2 i think and im pretty sure it only has 2 channels
08-23-2015, 01:50 PM | #7 |
Quarry Creeper Join Date: Aug 2013 Location: Wijnandsrade, NL
Yep, that is a 2 channel controller.... Only solution is that (and you may not like it ), is getting an other controller with receiver. Check Asiatees. They may come cheaper then you think.... Last edited by MaFoDes; 08-24-2015 at 12:17 AM. |
08-24-2015, 12:02 AM | #8 |
Rock Stacker Join Date: Feb 2015 Location: Grand Forks, ND
HeyOK makes a wireless controller. Working on a new Wireless Winch Controller Might be worth a look. |
08-24-2015, 03:35 PM | #9 | |
| Re: Scx10 Warn winch help Quote:
This is the part here: Wireless Winch Controller | |
08-24-2015, 07:41 PM | #10 | |
| Re: Scx10 Warn winch help Quote: when I purchased your wireless controller. But maybe that was not the case !? and so what is the difference of yours... Vs. the one offered by Yeah Racing ? curious... because it looks somewhat similar well... at least the FOB Amazon.com: Yeah Racing 1/10 Wireless Remote Receiver Winch Control Set #YA-0389: Home Improvement | |
08-25-2015, 07:25 AM | #11 |
I read lots of complaints of the other wireless controllers failing. My controller uses fairly heavy components to do the current switching to power the winch compared to what they use. My wireless controller is basically one of these, with the wireless part added on. 4 Amp Relay Output Winch Controller Kind of thought I made that clear in the description. |
08-25-2015, 04:08 PM | #12 |
^ guess you did... and I must've miss that or maybe I just forgot !? :doh: I bought fm you primarily, because your reputation/products are always the best. and haven't regretted my WC purchase since buying thanks for the ~just guessing~ 10k clarification |
Scx10 Warn winch help - Similar Threads | ||||
Who sells Warn winch decals for 3racing winch? | Wild Snapper | Scale Accessories | 6 | 12-03-2009 06:38 PM |
