08-27-2015, 12:41 PM | #1 |
Newbie Join Date: Feb 2015 Location: Florida
| longer lasting xr10 mod?
I have the XR 10 mod on my scx10 right now and my problem is that I wear out universals very fast. they get loose in the locker and then eventually strip Out. The last one i did i shaved down just enough to where i really had to shove it to get into the locker. I have splined tubes and hot racing lockers running od and ud with a roc 412. Gearing is 16 87 Is there a way to modify the universals so they last longer?. Is there another brand i should try? |
08-27-2015, 03:01 PM | #2 |
Pebble Pounder Join Date: Mar 2013 Location: Albuquerque
| Re: longer lasting xr10 mod?
I had problems breaking xr universals on my SCX, so I used Vanquish Wraith VVD,s. You will need to buy an additional long side shaft and machine them both down to fit. It may be a few less degrees in steering angle but they are bullet proof.
08-27-2015, 04:23 PM | #3 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
Sounds like you need Better lockers. Lockeduprc can fix you up
08-27-2015, 06:01 PM | #4 |
| Re: longer lasting xr10 mod? Do they offer more steering than the vvds for the scx10? Or are they basically the same, just made for wraith chubs n knux
08-27-2015, 06:25 PM | #5 |
Yeah, the issue is likely your spool. The Hot Racing are notoriously sloppy. I'd suggest getting a Locked Up R/C FI spool, a Holmes spool, or if you have the patience to set it up a Felsenfest spool.
08-27-2015, 06:27 PM | #6 |
OD/UD is gonna be harder on the lockers and the uni's tang. lose that if ya want a longer, more durable, user consumption. if no... get a harder locker... ie: F1 spool realize... if ya beat on yer rig... things will wear out. |
08-28-2015, 12:17 PM | #7 |
Ok, i wasnt aware that the hotracing wasnt hardened.. or that they used a different grade steel. I was assuming the fi and hr were the same, but its a cheap price to pay for the FI spool.. instead of new unis or always rewelding and reworkng them
08-28-2015, 04:09 PM | #8 |
| Re: longer lasting xr10 mod? Yep. That is why I run stock/UD gears, little less driveline abuse and still climbs and steers well.
08-28-2015, 04:47 PM | #9 |
Rock Crawler Join Date: Jan 2008 Location: P-TOWN
Like the others said its most likely the lockers because I have been using the same uni's for over a year. They have gotten sloppy but not too bad but I'm using quality spools. Also with your fast brushless system and the OD and UD gearing your putting a lot of pressure on your drive train because they are both fighting each other. I only run the OD gears up front and stock HD gears in back with my brushless wraith.
08-29-2015, 10:20 AM | #10 |
Mine were breaking at the uni, not the shaft. I us a fi spool. Nothing is going to give you more steering than the uni, but the vvds are tuffer. I am running a roc412 and od front. Sent from my SM-G900T using Tapatalk |
08-29-2015, 12:04 PM | #11 |
In the past I heated up the cut ends to cherry red and pounded them down to flare out slightly. With a case hardening dip in sugar and quench after grinding down to fit into the locker... no issues. YMMV of course.
longer lasting xr10 mod? - Similar Threads | ||||
VP knuckle mod on xr10 - Wraith or XR10?? | 001Hulk | Axial XR10 | 9 | 01-03-2012 01:15 PM |
