09-24-2015, 05:20 PM | #1 |
RCC Addict Join Date: Jun 2006 Location: Durham, NC, USA
| what screws to mount Hot Racing aluminum transmission case?
The Hot Racing transmission case is made out of 6061 aluminum. Therefore, the screws needed would be machine screws, instead of the self tapping, used for plastic. What screws would I need to mount the HR case to the skid plate from the bottom?
09-24-2015, 06:16 PM | #2 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
| Re: what screws to mount Hot Racing aluminum transmission case?
I am thinking a 3mm machine screw. The length would probably be the same as the self tapping ones. They would need to be counter sunk type not a pan head style. Hope this helps.
09-24-2015, 06:46 PM | #3 |
They are 3mm countersunk. I have the same case on my SS Bomproof trans. Also, the two that are spaced farther apart need to be shorter. I believe it's 2 3x10mm and 2 3x8mm.
09-24-2015, 07:59 PM | #4 | |
| Re: what screws to mount Hot Racing aluminum transmission case? Quote:
09-24-2015, 09:27 PM | #5 |
Quarry Creeper Join Date: May 2015 Location: RRW
fyi I used 4 3X12 flat head and it worked out ok.
what screws to mount Hot Racing aluminum transmission case? - Similar Threads | ||||
Hot Racing transmission case | WesTX | Losi Micro-Rock Crawler | 10 | 02-06-2015 07:26 PM |
Hot racing transmission case | Mudman02 | Axial Wraith | 0 | 11-14-2014 04:48 PM |
Aluminum Transmission case Hot racing or Vanquish? | DrDiff952 | Axial SCX-10 | 10 | 11-11-2014 04:10 PM |
Hot Racing Transmission case | BC-Brian | Axial XR10 | 15 | 11-15-2012 03:52 PM |
