Thread: Motor for stock gearing?
Old 10-11-2015, 12:46 PM   #1
Default Motor for stock gearing?
What kind of motor would you guys recommend for a scx10 on stock gearing? Mostly for trail use. II will be using 2s lipo.. I was thinking maybe HH torque master sport 35t?
Angry_dolphin is offline   Reply With Quote
Old 10-11-2015, 01:00 PM   #2
Default Re: Motor for stock gearing?
Are the integy lathe motors any good? Their like 10 bucks cheaper.
Old 10-11-2015, 01:05 PM   #3
MODERATOR™
EeePee's Avatar
They're not bad. Better than non rebuildable. 35 turn is a good choice. Having collected a gang of 35 turn motors I can confidently say there aren't huge differences between them. I dynoed em all and while the numbers did vary, it wasn't dramatic.
EeePee is offline   Reply With Quote
Old 10-11-2015, 02:08 PM   #4
i run the rc4wd 45t. 12 bucks i think, and pretty good for trail running.
donny8594 is offline   Reply With Quote
Old 10-11-2015, 04:31 PM   #5
snapon boy's Avatar
The integy motor is good for budget minded projects or if your gonna be in mud and water loads. On another note hh has a 30t for 25 I got 2 of them very happy with both and performance is better than axial silver can.
snapon boy is offline   Reply With Quote
Old 10-11-2015, 07:14 PM   #6
Rat
I've been running the rc4wd 45t on 2s. We hit a lot of water/sand each week, and it's cheap, but gets the job done.
Rat is offline   Reply With Quote
Old 10-11-2015, 08:02 PM   #7
I've got the hackmoto v2 35t in my sons scx10 and it has surprisingly good speed on 2 s. Wasn't expensive either. I think I paid around $20 on eBay or rcmart.com has them too.
Ghonda99 is offline   Reply With Quote
Old 10-12-2015, 09:07 PM   #8
A 27-35T will do the trick for a good balance between speed and crawl. Any more turns on the motor and you loose out on those short bursts of speed when you need to get over something and a slow crawl just won't do it.
scaled is offline   Reply With Quote
Old 10-12-2015, 09:37 PM   #9
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
It's not a dramatic difference on the dyno between 21g and 20.5g wire, but you can feel the difference driving. If a bit better quality wasn't noticeable we wouldn't have gotten past lathe motors to begin with. I would like to think that there is a wide variety of brushed motor options because they are all have a good place within the budget.
The old integy matrix motors were decent, back when they used epic. The new cheap ones are barely a notch above stock sealed cans. On the topic of less expensive options, we have just gotten TrailMaster Sport motors back in. We sprung for stronger magnets, better brush compound, and a bearing on the pinion side to wake them up compared to stock sealed cans.
Holmes Hobbies LLC TrailMaster Series
JohnRobHolmes is offline   Reply With Quote
Old 10-12-2015, 09:59 PM   #10
snapon boy's Avatar
I forgot to mention that the service and customer support with Holmes Hobbies is outstanding. I just bought a torque master and it had a hung brush I had never had that happen I emailed, and got a response within an hour of how to fix my issue. The next day I got a follow up email to make sure all was well. This is how life time customers come about. Thanks for making the hobby fun.
Old 10-12-2015, 10:07 PM   #11
MODERATOR™
EeePee's Avatar
I used the words, huge and dramatic on purpose.
Motor for stock gearing? - Similar Threads
Axial 27T Motor good on stock gearing Wraith Spawn? raider89 Axial Wraith 4 06-04-2015 03:38 PM
Best motor/gearing for 1s or stock 4.8V pack? 89redranger Losi Micro-Rock Crawler 7 10-08-2013 02:20 PM
Over heating motor with stock gearing! ms4x4outlaws Axial Wraith 2 12-02-2011 07:57 PM
motor and stock gearing? ped453 Newbie General 1 11-23-2009 02:37 PM
Which lathe motor for WK stock gearing? MikeSSS HPI Wheely King 6 05-10-2007 09:15 PM
