10-16-2015, 07:35 AM | #1 |
Quarry Creeper Join Date: Sep 2005 Location: Minneapolis
| SCX10 Trans mirror/flip not going back together
Picked up a RTR CRC edition JK; it's fun, and I'm surprised how well it handles right out of the box. Not that torque twist is much of an issue, but I decided to mirror and flip the trans to try and improve performance a bit. I got it all done, and the trans won't sit flush on the skid plate because the stock motor is too long and hits the nut holding the passenger front link to the frame. Is that common? It seems if I used a shorter motor (like an Integy lathe motor, etc) it would be fine. Any ideas besides buying a new motor? |
10-16-2015, 07:37 AM | #2 |
Rock Crawler Join Date: Sep 2011 Location: truckee
| Re: SCX10 Trans mirror/flip not going back together
It's common. Can you flip the screw and put the nut on the outside?
10-16-2015, 07:47 AM | #3 |
Possibly. The shaft of the screw clears the motor can by a hair, but not quite enough room for the nut. I'll check that out tonight after work.
10-16-2015, 09:58 AM | #4 |
When I mirror the trans, do I also want to rotate the skid plate 180, or leave it in it's factory configuration?
10-16-2015, 10:12 AM | #5 |
Rotate the skid so the motor stays in front.
10-16-2015, 11:40 AM | #6 |
X2 and I use a shorter screw with a thin locknut from my Wraith kit, part number AXA1052 Axial 3mm Thin Nylon Locking Hex Nut Set (Black) (10) [AXIA1052] | Parts - AMain Performance Hobbies - AMain Performance Hobbies |
10-16-2015, 08:36 PM | #7 |
Good call, thanks nate! I flipped that screw around and that worked for now. If I find there is a noticable improvment tomorrow, i'll keep it this way and order the nuts and screws. |
10-22-2015, 05:02 PM | #8 |
Update: Flipping that screw around did the trick. Yeah, it's more of a hassle getting things back together, but it works; thanks for the tip! Regarding performance, it didn't seem to do much so far. I guess it did help some, but not enough to outweigh removing the gear cover. I'll give it a couple more runs and see. |
10-22-2015, 05:18 PM | #9 |
You're welcome and it was noticeable for me, removing gear cover is not done that often and sometimes I leave the one pita screw out of the cover.
SCX10 Trans mirror/flip not going back together - Similar Threads | ||||
whats it mean to mirror the trans? | slashbasher | Axial SCX-10 | 28 | 01-06-2016 01:57 PM |
Mirror Trans. | crawliestsalinan | Axial SCX-10 | 6 | 10-26-2012 08:27 PM |
mirror or flip tranny? | axial 888 rtc | Axial AX-10 Scorpion | 10 | 08-08-2010 08:25 PM |
Mirror trans?? | Brandon13 | Newbie General | 4 | 02-18-2009 11:34 AM |
mirror trans ? | broncoholic | Axial AX-10 Scorpion | 3 | 12-07-2008 09:43 PM |
