11-07-2015, 11:08 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: York
| ssd and vanquish links problem
whats up guys, putting my ssd d60 axles under my scx and the vanquish 3 link seems to be too long and pushes my axle forward and tilts the diff cover towards the ground.... anyone else have this problem.? tmw im going to loosen the bottom links but seems like a crappy fix
11-08-2015, 09:40 AM | #2 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
| Re: ssd and vanquish links problem
Hard to tell without pictures, but you might be able to swap one end of the lower links with jato rod ends. The jato ends are a little longer.
11-08-2015, 06:27 PM | #3 |
Quarry Creeper Join Date: Feb 2012 Location: Verdi, Nevada
Lower link mounts and upper link mounts in same spot as stock
11-09-2015, 02:48 AM | #4 |
Newbie Join Date: Jun 2015 Location: Rockledge
I had the same issue. My fix was to use the plastic 3 link arm mount that came with the SSD axle (Really did not want to go this route since I just dropped some good coin on the VP 3 link). As for the bent titanium arm that is supposed to connect to it I had to put that in my storage bin and use a shorter VP link that I had. I cant recall the size but it wasn't that much shorter, maybe 2-4mm. Took some time to get the alignment dialed in but it worked. I didn't even bend the new bar. Works just fine.
11-10-2015, 11:17 AM | #5 | |
| Re: ssd and vanquish links problem Quote:
11-10-2015, 02:02 PM | #6 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
What Nate said. |
ssd and vanquish links problem - Similar Threads | ||||
New SSD Titanium Links for SCX10 | SSD | Axial SCX-10 | 28 | 06-16-2016 10:45 AM |
SSD Steelies & Vanquish OMF rings. Compatible? | turbodan13 | Tires and Wheels | 6 | 08-17-2015 03:04 PM |
New SSD Titanium Links for Wraith | SSD | Axial Wraith | 0 | 06-05-2015 03:15 AM |
Vanquish or SSD-RC CMS? | T4rscott | Axial SCX-10 | 0 | 03-27-2015 11:02 AM |
