11-19-2015, 11:20 AM | #1 |
Pebble Pounder Join Date: Aug 2008 Location: Cary, NC
| OD/UD gearing preference
I'm looking for a little more wheel speed on the front of my scx10 to help with climbing. Wondering what you would suggest. Over-drive the front axle 36/14 rear 38/13 or under-drive the rear 43/13 front 38/13. Your suggestions are greatly appreciated. (In what fashion is my rear suspension setup going to effect my choice) Thanks, Neil Last edited by nsg1rc; 11-19-2015 at 11:52 AM. |
11-19-2015, 11:24 AM | #2 |
| Re: OD/UD gearing preference
There's got to be two dozen threads about the exact same subject. It's a preference and based how the rear suspension is set up.
11-19-2015, 01:05 PM | #3 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
The UD gears are said to have the best mesh pattern, you also reduce torque twist by increasing the gear reduction in the axle.
11-19-2015, 03:09 PM | #4 |
RCC Addict Join Date: Jul 2009 Location: Ontherocks
I run OD front and stock rear. Yea the OD isnt as strong but it has held up fine in my brushed wraith that is pretty much a dedicated crawler anyway. I guess it depends on how hard you are on rigs and what kinda power/weight you are dealing with
11-19-2015, 06:02 PM | #5 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
Both.
11-19-2015, 07:38 PM | #6 |
Rock Stacker Join Date: Feb 2015 Location: Grand Forks, ND
Got a set of OD in my rig, I like it. If that was the "best" one to do, I don't know, but the OD works.
12-12-2015, 10:01 PM | #7 |
Quarry Creeper Join Date: Apr 2006 Location: SLC, Utah
I run both OD and UD works great on the local comp courses that are tight and technical
12-13-2015, 08:42 PM | #8 | |
Quarry Creeper Join Date: Oct 2012 Location: Malang, Indonesia
| Re: OD/UD gearing preference Quote:
OD/UD gearing preference - Similar Threads | ||||
Motor/esc preference? | Chaotic Crawlers | General Scale Talk | 1 | 03-06-2011 11:53 AM |
Gear size preference? | Brainstain | General Crawlers | 4 | 04-23-2008 09:33 AM |
