11-21-2015, 04:17 PM | #1 |
Quarry Creeper Join Date: Aug 2015 Location: Grover, NC
| Do you guys lube your shaft joints?
Do you guys regularly lube or grease the drive shaft joints or CVD joints? I was just curious of this if this should be a routine thing to do
11-21-2015, 04:23 PM | #2 |
Pebble Pounder Join Date: Jun 2006 Location: newark
| Re: Do you guys lube your shaft joints?
if playing in the mud yes regular trail run I don't
11-21-2015, 04:25 PM | #3 |
I get in mud/water on almost (almost) every run.
11-21-2015, 05:58 PM | #4 |
Rock Stacker Join Date: Jul 2014 Location: Hillsboro
Lube up my shaft? Oooh yaaaa. |
11-21-2015, 06:23 PM | #5 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Dry silicone or dry graphite spray |
11-21-2015, 06:32 PM | #6 |
Rock Crawler Join Date: Jan 2012 Location: middle TN
Porn hub and dry here
11-21-2015, 06:42 PM | #7 |
Pebble Pounder Join Date: Apr 2013 Location: Bonney Lake
I lube my XVD joints and other CVD style joints like axial stock drive shafts with Lucas red and tacky grease and clean off the excess after initial rotation check for smoothness. Never broke An axial CVD on 2 scx10s and a wraith and a ax10, and only broke on first gen xvd. Just my experiences, but I like to keep metal on metal moving parts lubed. But as stated depending on conditions dry graphite may be more beneficial. Sent from the clouds |
11-22-2015, 07:24 AM | #8 |
Newbie Join Date: Nov 2015 Location: Peoria
I always clean and put the Lucas red and tacky on my shaft joints. The water will cause rust terribly fast if not. This works well on my rigs but it depends what environment you run in.
Do you guys lube your shaft joints? - Similar Threads | ||||
the tranny, to lube or not to lube that is the question... | cliffdawg | Team Losi Comp Crawler | 11 | 04-13-2011 03:07 PM |
R2Ds- Lube? - Monster Lube worth it? | gr33nlite | Tamiya TLT Crawlers | 2 | 12-14-2007 09:00 AM |
U-joints? | deadcell | General Crawlers | 8 | 03-14-2007 02:07 PM |
drive shaft u joints | Bknight | Newbie General | 9 | 10-12-2006 03:07 PM |
Lube TLT-1 stub axle to inner axle shaft or run it dry??? | Natedog | Tamiya TLT Crawlers | 5 | 01-17-2006 02:53 AM |
