11-24-2015, 04:14 PM | #1 |
Pebble Pounder Join Date: Jun 2006 Location: newark
| rear battery
Ok ladies and gentleman , I know we want as much weight as far forward as possible . But what if due to trans position and links you couldn't do that ? where would you run the battery (side mount or rear ) could you still keep the front end down using beef tubes and weighted wheels .
11-24-2015, 04:18 PM | #2 |
I wanna be Dave Join Date: Nov 2014 Location: West Texas
| Re: rear battery
Pictures so we can see what's up.
11-24-2015, 04:31 PM | #3 |
| Re: rear battery
wraith trans backwards with dig ,sorry cant post pics till later
11-24-2015, 06:16 PM | #4 |
| Re: rear battery
Ok. Side ways
11-24-2015, 07:33 PM | #5 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
What size batteries do you run..?
11-24-2015, 09:28 PM | #6 |
| Re: rear battery I use two 2200 mah 3S batteries wired in parallel with a Roc 412 3100KV. I am getting around a 45 minute run on the trails with it. I am using the R2J sliders which have a solid plate so it is easy to mount a battery on each side. Better overall weight distribution for crawling up and down the hills. |
11-25-2015, 01:18 PM | #7 |
| Re: rear battery |
11-25-2015, 02:08 PM | #8 |
| Re: rear battery
I run dual 2200 mah 3s wired parallel. with those mounted atop the original sliders. tools/materials utilized: ...1/8" lexan sheet stock ...quality hobby grade heat gun (to bend lexan) ...common vise (to bend lexan) ...drill press with drill/chamfer bit for the holes. ...slightly longer 3mm screws with nylock nuts at the bottom to secure. ...parallel wiring harness (if wanting to combine mah capacity)* * you don't have to run a parallel harness and combine both batteries you can deplete them individually. But it's a hassle to have to switch batteries. Both need be on board tho' so as to off set each other in weight. Dual batteries need be the same ratings. A 5000 mah 2s is generally too long ( heavy too ) to mount atop the sliders. ^ purdy simple to do... without spending too much coin. \ or... you could get more elaborate and make your own sliders |
rear battery - Similar Threads | ||||
Rear Battery area reinforcement | SamuraiTrapper | Axial Wraith | 3 | 03-06-2012 12:58 PM |
Battery pack on rear axle? | rcjackson0926 | Team Losi Comp Crawler | 7 | 03-23-2010 02:11 PM |
Rear Carbon Battery Plate. | es79 | Axial AX-10 Scorpion | 4 | 03-18-2010 03:35 PM |
Battery on rear axle... why not? | syber70 | Axial AX-10 Scorpion | 10 | 01-02-2009 02:10 PM |
Battery placement above rear axle? | Aurora | Axial AX-10 Scorpion | 9 | 11-20-2008 10:25 AM |
