12-05-2015, 12:59 PM | #1 |
Newbie Join Date: Nov 2015 Location: Middle East
| Wrangler LED headlight + electrical works
Hi, folks! Note: below is applicable for Raspberry Pi, it does not apply to normal RC receiver. I finished making LED headlight for my Wrangler. Took some time to figure out robust way that will allow to put more payload, and to allow more current output. I ended up with using Adafruit DC motor hat, stacking it on top of PWM hat. The driver allows 4 channels 1 Amp current each, which should be more the enough to power LED. Software (btw, same code as for PWM driver) allows to adjust voltage. I used two 3$ LED finger-size flashlights, from which I took the head part with glass and reflector (I will later add photos of lamps themselves), 1.5V. Note: it looks like mine Chinese flashlights did not have any resistor and were relying just on battery self-resistance to limit current, or resistor was in battery holder which I did not use, therefore watch out for over-current. Always use Amper-meter. Light is controlled with same PS4 controller as car itself. Plan is to add more lights, including LED bar (I want to make it myself though, rather then buying). |
12-07-2015, 11:47 AM | #2 |
| Re: Wrangler LED headlight + electrical works
As promised, photo of lamps from inside cover + some photos and vid. https://www.youtube.com/watch?v=lg3g...ature=youtu.be |
Wrangler LED headlight + electrical works - Similar Threads | ||||
LED headlight..is there a kt? | 98TealJ | General Crawlers | 16 | 07-19-2006 04:53 PM |
scale wrangler project in the works... | chaos18 | Tamiya TLT Crawlers | 24 | 02-08-2005 06:40 PM |
