12-06-2015, 08:39 AM | #1 |
Rock Stacker Join Date: Jan 2014 Location: Eagle Rock
| parnhard bar questions
hey guys how do i adjust or setup and parnhard bar correctly? i have a lot of bump steer? |
12-06-2015, 11:19 AM | #2 |
RCC Addict Join Date: Apr 2010 Location: Outdoors
| Re: parnhard bar questions
This is a good read if you haven't seen it already 3/4 Link for Dummies |
12-06-2015, 04:25 PM | #3 |
I wanna be Dave Join Date: Jun 2004 Location: San Jose
The panhard bar or Trac-bar is designed to locate the axle left to right. If you making your own set up I highly recommend using a turnbuckle with both left and right handed threads to adjust it on the rig. If you have bump steer it's because the drag link and panhard bar are not at the same length or angle. A pic of your rig will help us help you.
12-07-2015, 07:53 AM | #4 |
| Re: parnhard bar questions |
12-07-2015, 09:46 AM | #5 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
I think i would make a new taller bracket on the axle side , so that your drag link and track bar are parallel.
12-07-2015, 11:02 AM | #6 |
Or... Put your tie rod under the knuckle, and your steering link on top, that should get your angles close without any other mods.
12-07-2015, 11:58 AM | #7 |
ill try that the knuckle thing. i was also thinking about buying the mount from vanquish. |
12-11-2015, 07:17 PM | #8 |
Quarry Creeper Join Date: May 2012 Location: Portland
Are you sure what your getting is bump steer? (when you compress your suspension your steering is turning?) I've seen a lot of people complain about bump steer when that's not at all what is going on. |
12-12-2015, 06:51 AM | #9 |
parnhard bar questions - Similar Threads | ||||
Light Bar questions! | Banjoblue | Electronics | 1 | 07-03-2015 06:02 AM |
more yeti xl sway bar questions. | sj4x4 | Axial Yeti XL | 3 | 03-15-2015 08:56 PM |
Rear Sway Bar Questions (Pic Request) | Coastie07 | Vaterra Twin Hammers | 32 | 04-23-2013 12:49 AM |
