12-10-2015, 10:03 AM | #1 |
Newbie Join Date: Dec 2015 Location: Oconee County, SC
| Dual battery ?
Moving the battery down to the rock sliders. Gonna carry two to balance the weight. Here's the question that I can't make up my mind on..... Do Y'all run the batteries in parallel for the increase in run time (mah) or just run single battery and switch out when one get's low? MG][/IMG] Last edited by Redbone; 12-10-2015 at 10:05 AM. |
12-10-2015, 10:17 AM | #2 |
| Re: Dual battery ?
Parallel for run times is what i do..usually a pair of 3s 2200mah up to 3300 according to what works best for whatever rig I am building
12-10-2015, 01:59 PM | #3 |
| Re: Dual battery ?
Yup, gettin' some flex now without it on it's lid [IMG][/IMG] [IMG][/IMG] It's tough to video and drive at the same time....Used to have to work at this, now with the weight of an extra battery, she just goes up and over without a hitch. https://www.youtube.com/watch?v=bf1xsQ6yQZs |
12-10-2015, 02:11 PM | #4 |
| Re: Dual battery ?
I run my dual 3s 2200mah's wired parallel My son runs his dual LiPo's... one at a time. but both still reside on the sliders to create an equal ballast. I like the additional weight associated with running dual 3s 2200's. But doubt I'd want to go with a heavier LiPo. |
12-10-2015, 02:17 PM | #5 |
| Re: Dual battery ?
I'm running 5000 mah 6 cell nihm, now one on each side, get 1 1/2 +/- hours out of one, has plenty of wheel speed with the 27t motor with 14/86 gears. I save my lipo's for the go fast trucks. I might go ahead and wire it for parallel when I get a little more wrench time available.
12-10-2015, 03:31 PM | #6 | |
| Re: Dual battery ? Quote:
you can purchase a parallel "Y" harness that includes dean ultra plugs for connection. (plug n play) I purchased mine from Castle Creations # 011-0006-00 Castle Creations | Castle Parallel Wiring Harness There are plenty others mfgr's of this harness including those listed/sold on ebay. Tho' I must add... the Castle Creation's "Y" harness is decent quality and possibly more durable then some others. oh if you're going to run dual batteries parallel be sure both battery's are equivalent having the same voltage and mah Last edited by TacoCrawler; 12-10-2015 at 03:36 PM. | |
12-10-2015, 03:36 PM | #7 |
| Re: Dual battery ?
Yes sir know all about that.... Can make my own easy enough, have plenty of 10 Gauge wire and connectors. That way it gets made to fit the truck without a bunch of excess wire hanging around like spaghetti.
12-10-2015, 08:28 PM | #8 |
| Re: Dual battery ?
I tucked mine up next to the tranny since I don't run sliders anymore on that one. Same principle, though, and I run them parallel. 2200mAh each and usually I get bored before they get low. |
12-11-2015, 08:39 AM | #9 |
Pebble Pounder Join Date: Jun 2014 Location: MA
| Re: Dual battery ?
with the batteries in the first pic in parallel thats 10000mah total, wow would probably run for ~2 hours! saddle packs work pretty well mounted on the sliders if you are looking for another option.
12-11-2015, 08:49 AM | #10 |
I wanna be Dave Join Date: Jan 2009 Location: New Port Richey, FL.
| Re: Dual battery ?
I run a pair of 3s 4000mah lipo's in parallel on the sliders on my ascender.
12-11-2015, 11:08 AM | #11 | |
So that's my thinking on the subject. Still undecided as there's really no real benefit except run time. Might just make a connector for those days I spend on the trail. Just trying to get a general consensus here to possibly sway me one way or another. | |
12-11-2015, 11:33 AM | #12 | |
Dual battery ? - Similar Threads | ||||
Dual battery EVX | 1of1547 | Electronics | 8 | 04-20-2010 10:34 AM |
wiring diagram for dual esc's, dual servos, bec, and one battery??? | jedsled | Tamiya Clod Buster | 6 | 11-13-2008 07:36 AM |
Dual battery set-up? | rroberto1 | Electronics | 15 | 01-03-2008 10:59 AM |
Dual battery kits or controlers? | Magic | Chit Chat | 13 | 06-25-2007 01:13 PM |
Dual Battery packs??? | jonathonsn | General Crawlers | 7 | 10-07-2005 08:27 PM |
